While I'm waiting for Brian of Corvette Specialties to straighten out my fuel gauge, I got bored and replaced all the 'gray wire' dash bulbs in the cluster with LEDs.
The bulbs gave off a warm glow at night but even at full blast the dials were hard to see.
Wow, nice difference. I managed to get all the LEDs in the cluster, clock and radio mounted in the bulb sockets from the driver's side of the car with the dash cluster still installed. No fun - but its done now..
Very nice Frankie! What an improvement! I know there are a number of threads on this conversion, but would you post up the specific type of LED bulbs you used and their source.
While Frank is looking that up, here's the LED bulbs I put in my dash from Superbrightleds. As Frank mentioned, these BA9S bulbs can be used for all grey wire dash lights (not for the 257 flasher bulbs). You can get them in both warm white and also cool white which is much whiter and brighter than warm white. Two great things about LEDs ... they are much brighter and they will not likely burn out in your lifetime. Bill
I used these from SuperBrightLEDs; I didn't want the light to be too harsh or glaring so I went with the warm white over the cool white. Some had problems with the LEDs fitting tight enough in repro harness sockets. These fit fine in my harness...:
It took exactly 10 for the gray wire bulbs in the 63 (other years need more I recall); 7 in the cluster, 2 in the clock, 1 in the radio...
It would be MUCH easier with the dash removed....but I have pianist fingers and monkey arms and can snake my upper limbs into places most cannot. Wife says they are "Go-Go Gadget" arms....
I DID remove the five screws holding the cluster and move it out an inch or two and that was enough room for me... You can see a bit of the space around the steering column in the pic above in post #1.
The problem is not snaking your hands in there to get the bulb near the socket, its getting enough 'umph' to seat the socket firmly back into the hole with your hand in an awkward position that doesn't allow much force to be applied. On some of the bulbs I had to do it 'blind' - there was no seeing where the bulb actually was; it was all by feel.
