Leaf Spring
Old Apr 3, 2018 | 10:02 AM
droederer's Avatar
droederer
Default Leaf Spring
I saw on the forum where someone had moved their leaf spring inside the frame rails by notching a cavity in the rail itself on the front mount and the rear mount ends up being just under the rear crossmember. This drops the Leaf spring to almost level. From factory it is about 5" higher in the rear.
obviously the pinion angle changes, but what are the other pros/cons of doing this.
I'm doing this on a 1956
Old Apr 3, 2018 | 10:41 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
If I remember, the idea behind that was to run a set of Cal-tracs and get a set of 10" slicks back there. Don't know if the car was ever finished, but I'm betting the the car will really hook up. I'm curious, what is your end goal ?
Old Apr 3, 2018 | 01:07 PM
droederer's Avatar
droederer
Just looking to go to a little wider tire and pretty much keep a spring setup. Thinking 4 link is overkill as I don't want to race it or anything. Most just some nice street performance
Old Apr 3, 2018 | 02:05 PM
Loren Smith's Avatar
Loren Smith
You will only gain an inch without tubbing the inner wheel wells. And if you tub, your convertible top won't fit.
Old Apr 3, 2018 | 02:49 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Intuitively, with the springs inside the frame rails, they probably will be less able to oppose body roll when cornering. If my intuition is right, it means the car will understeer more at the limit.
To Leaf Spring
