[C2] 1964 Convertible - Plain Jane - The Journey Begins.
Old 01-18-2019, 11:46 PM
  #181
hcallaway
Support Corvetteforum!
hcallaway's Avatar
Originally Posted by elwood13
Is that a 10’ trailer? I think my 8’ is going to be a bit short to take the frame to the powder coater.
7 x 10
I think with your tailgate off it will do the job. I brought the frame back from PA in a 12’ enclosed trailer and shut the door.
Old 01-20-2019, 11:30 AM
  #182
hcallaway
hcallaway's Avatar
Default Birdcage Sealants Removed and Cleaned
Glad that is out of the way.
Old 01-24-2019, 06:52 PM
  #183
hcallaway
hcallaway's Avatar
Default Paint Questions I asked in the Paint Subsection.
64 Originally Daytona Blue with one respray. It was painted sometime before 1974 as this was done before the second owner. I am pretty sure it is not a lacquer paint and I don’t think that is pertinent to my real question.
I think I am looking at some bare fiberglass, red primer and maybe a high build primer?
Paint stripper did a pretty good job after roughing up the surface top coat. Is the material on top of the primer original?
I don’t see any signs of the dark blue. It is hard to imagine it was all sanded off before the respray.
All the bonding strips are visible so that is a good sign.
Last edited by hcallaway; 01-24-2019 at 08:08 PM. Reason: Seems like there are not enough activity on that part of the forum.
Old 02-05-2019, 08:01 PM
  #184
hcallaway
hcallaway's Avatar
Default Still am still learning how to use paint stripper on fiberglass.
It is a slow process but it is getting faster and I am developing a rhythm.
Old 02-05-2019, 08:42 PM
  #185
elwood13
elwood13's Avatar
Received 1,886 Likes on 1,078 Posts
That looks good. It is definitely not a fast process unless you have Pat and his minions. Keep up the good work.
ptjsk (02-16-2019)
Old 02-16-2019, 05:12 PM
  #186
hcallaway
hcallaway's Avatar
Default Added additional support to #4 body mount.
A little more tweaking as I have never felt it is where it should really support the *** end of the car.
Old 02-16-2019, 10:44 PM
  #187
ptjsk
ptjsk's Avatar
Received 1,901 Likes on 883 Posts
I ended up cheating, and taking it to the stripper. They used plastic media and it worked out real good. But still a ton of work getting it ready for paint.
Pat
Old 02-22-2019, 05:26 PM
  #188
hcallaway
hcallaway's Avatar
First Grandkid to help on this project. My 3 sons can get in line on my side.
First real signs of the Daytona Blue.
Door gaps are looking pretty good. I hope I don’t lose it when we replace the drivers door. I can easily tighten the gaps with the floor jacks on the rear mounts.
How many people paint the shell with the doors installed?
Old 03-04-2019, 07:54 PM
  #189
hcallaway
hcallaway's Avatar
Default Carpet removed.
I am not going to remove all the glue remnants.
Old 03-04-2019, 08:02 PM
  #190
hcallaway
hcallaway's Avatar
Default Degreased under rear shell.
I removed all the grease and have started to do another round of paint thinner and wire wheel. Does anyone remove the factory undercoating. I don’t see how you can clean it with it being so porous.
Old 03-04-2019, 08:07 PM
  #191
elwood13
elwood13's Avatar
Looking good. The carpet glue was not fun but I probably did more than I needed. 3M adhesive remover and razor blades were my friend. Turns out the paint stripper worked better but don’t know if it is recommended.
Old 03-04-2019, 09:14 PM
  #192
Railroadman
Railroadman's Avatar
Received 5,010 Likes on 2,529 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
That's about where I am on mine, and that's the same decision I made on mine! I'll sand down the rough parts and remove what's loose, but that young guy in Texas has way more energy and determination than this old coot!
Old 03-04-2019, 09:27 PM
  #193
elwood13
elwood13's Avatar
Lol Don. Don’t know if it’s energy, ocd or stupidity.
Old 03-13-2019, 06:19 PM
  #194
hcallaway
hcallaway's Avatar
Default Kicking my ***. Paint Stripping Continues!
I am about 60% done.
Old 03-13-2019, 07:16 PM
  #195
elwood13
elwood13's Avatar
That body looks good. I got to thinking about it and I don’t know if it was the cold or if kleen strip changed their product. The first two gallons I had were fairly clear and stripped the paint fast. That last gallon I bought was cloudy and took a lot longer on the hardtop.
Old 03-13-2019, 08:05 PM
  #196
hcallaway
hcallaway's Avatar
Default New Can Opened Clear Liquid
The Kleen Strip has a yellow tint. It definitely works better in 70 degrees than when I was stripping in 40 degrees.
ToySnakePMC (03-14-2019)
Old 03-14-2019, 07:07 PM
  #197
hcallaway
hcallaway's Avatar
Default One fender down and one to go.
Shooting to be doing door jams on Saturday.
This fender had some work on the front leading edge.
To 1964 Convertible - Plain Jane - The Journey Begins.
Old 03-14-2019, 07:10 PM
  #198
64SilverbluePhx
64SilverbluePhx's Avatar
Looking great you are making excellent progress!
hcallaway (03-14-2019)
Old 03-14-2019, 07:49 PM
  #199
hcallaway
hcallaway's Avatar
i am going back to the Daytona Blue. Your 64 is very close to the color of our car as it is now. I think my brother would like to keep it that lighter blue like yours.
Old 03-14-2019, 08:15 PM
  #200
64SilverbluePhx
hcallaway is Daytona Blue a '64 color? Just curious on that. Daytona Blue will be a great color! Both colors will show off your car's lines beautifully!
Quick Reply: [C2] 1964 Convertible - Plain Jane - The Journey Begins.
