Carter AFB setup
Old Apr 13, 2018 | 11:37 AM
TX63CONV's Avatar
TX63CONV
Default Carter AFB setup
I am having an issue with my choke housing on a recent rebuild (see other post). This has been on the shelf and some pieces were disconnected.
Does this look correct? It appears the secondary will not open all the way until the choke is fully open?
Old Apr 13, 2018 | 11:59 AM
SWCDuke's Avatar
SWCDuke
OE AFBs have a "secondary throttle lockout"feature that prevents the secondary throttle valve from opening until the choke is released.
The '63 Corvette Shop Manual has an excellent section on the AFB and goes over all the checks and adjustments (including the secondary throttle lockout) needed to be sure its properly calibrated for all operating conditions from cold start to WOT.
Duke
Old Apr 13, 2018 | 01:48 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Several things happen when the choke is engaged, first off - the fast idle cam steps up the idle, next the secondaries are temporarily locked out so a novice driver doesn't drown the cold engine in oceans of gas until its warmed up. This is how it should be hooked up.
The swivel where the top of the choke rod attaches is different on your carb - I can't say for sure if that's right or not...it may not be...
Old Apr 13, 2018 | 02:32 PM
TX63CONV's Avatar
TX63CONV
Thanks. I ll review my shop manual.
Frankie—forgot to mention this is a 3721 ‘replacement’ carb. That may be the difference. I’m not going for NCRS, just trying to use all the chrome pieces I bought :-)
Old Apr 13, 2018 | 03:29 PM
Frankie the Fink
Army
The one in all my pictures is a 3721 as well - they are very fine carbs when set up right...
To Carter AFB setup
