Dash reinstall
Old Apr 14, 2018 | 09:54 AM
vjjack04's Avatar
vjjack04
Default Dash reinstall
Guys,
I am putting my dash back in after wiring and Vintage Air install. I have the factory manual so I think i got it...other than the bolts/washers across the top, the rivets on each door area, and some sort of adhesive at the trans tunnel...what else? Any tips? I don't have new pads yet, will they be too tough to install if the dash is already in?
Johnny
Old Apr 14, 2018 | 10:25 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I would wait until you have new dash pads before installing the dash.
Old Apr 14, 2018 | 10:54 AM
VetteZr's Avatar
VetteZr
Old Apr 14, 2018 | 11:02 AM
vjjack04's Avatar
vjjack04
Thanks guys. I will just put it in with a couple bolts temporarily to ensure I have all the gauge cluster wiring right...then when i get the pads, i will put it in permanently....
Old Apr 14, 2018 | 11:52 AM
johngandersonjr's Avatar
johngandersonjr
Some put the dash in and then the wiring. that way you can completely wire the cluster before you install. I think the factory did it this way.
I am in the same boat right now. I have my dash out to dye my dash and pads. I am going to re-install the dash without the wiring, then install the cluster and harness together.
Old Apr 14, 2018 | 01:31 PM
66/427's Avatar
66/427
From: Born and Raised in South Detroit (Windsor) Ontario
Default dash
I agree with the group, just finished installing my dash and cluster last week, one thing I want to mention is after I put the dash in I checked to make sure the console side screws would line up with the brackets, they did not, so I had to adjust the lower part of the dash a little so the console could move forward a 1/4 in. before final gluing and screwing in place, just check before gluing the lower section.
Ric
Old Apr 14, 2018 | 03:14 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I put em in separate, never had an issue.
Old Apr 14, 2018 | 03:29 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Ric
On most midyears you don't even need to glue the center waterfall - the horseshoe molding will hold it in just fine. And I don't care what anybody has said or done....installing dash pads is 10X easier with the dash OUT of the car...
Old Apr 14, 2018 | 07:42 PM
vjjack04's Avatar
vjjack04
Just to clarify, no sealer is used where the dash bolts to the windshield area of the bird cage, right?
Old Apr 14, 2018 | 07:44 PM
Frankie the Fink
Army
Correct. NO sealer...
Old Apr 14, 2018 | 07:50 PM
MAD IN NC's Avatar
MAD IN NC
Crowd Plow For Now
been there .. done that 100% right
pads first, radio speaker - make sure all don't rattle then cluster.. horseshoe console holds all down when installed properly
To Dash reinstall
