[C1] Headlight switch mounting issue.
2023 C1 of the Year Finalist - Modified
Well I am stumped. This is on my 1960. I removed the old cooked headlight switch and found three large washers between it and the dash. When I got the new switch I fit it to the dash and lined up the tang in the slot, it all looked good. Threaded the nut down with the bezel in place and it stopped with about three washers of clearance remaining. I thought this must be the wrong nut, long with the threads not going all of the way to the head. I looked up the 1960 Vette nut and it looks identical to mine. I see no spacer required on a 60 like a 56/57. so what am I missing? Is there a fatter bezel? Is my dash too thin?(joke). The full size Chevy light switch nut looks correct, but I won't go there if I am missing something.
Thanks in advance, cause I know you guys will have the answer!
Incorrect switch ?
Can't imagine what else it could be...
I am assuming you ordered a switch for a 58-63 but are you sure you have the correct nut for a 58-60. It may be you have a different year headlight nut. The 61,62 nut is shorter than the 58-60, and the 63-67 nut is longer than the 58-60. That is probably the reason for the extra washers. May want to check the length of the correct headlight nut with a corvette parts vendor to confirm what you have. Just a thought. Thx
Thanks.
I think I figured it out. GM changed the instrument panel in 1961 by removing a built in spacer for the light switch (among other things), that required a longer nut. I have the right switch and nut, but bubba changed the instrument panel and it is a 61. I just ordered a 61 nut that should work.
Not surprising - the clusters are pot metal and prone to breakage when messed with by the unwitting, or even the witting...
Mint 66 (04-18-2018)
The easiest way to tell a lower instrument cluster is by looking at the cigarette lighter hole. 61-62 has a raised ring around the circumference of the hole—58-60 did not. There are other differences, but that is the easiest to ID.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Here is a 61 cluster
