[C2] Manifold pipe plug
Old Apr 26, 2018 | 10:18 PM
tubman's Avatar
tubman
Default Manifold pipe plug
I have a '67 coupe with an L79 engine. I recently had the valve seals replaced and am in the process of re-assembly. Since the car is pretty "bare-bones", (no A/C or PB) the threaded hole on the top of the intake manifold behind the carburetor has just a plain pipe plug in it (no special fitting). I am wondering if this is correct or is there a special plug required. This looks just like a 3/8" pipe plug you would buy at the hardware store with a square head. A picture of the correct plug in situ would be appreciated.
Thanks.
Old Apr 26, 2018 | 10:40 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I don't really know what a stock plug would look like but a aluminum plug with recessed allen head looks better than a square steel pipe plug. Unless it's an iron intake then a iron plug with recessed allen head would be a better match. Most hardware stores should have'm.
Old Apr 27, 2018 | 09:12 PM
JohnZ's Avatar
JohnZ
Without A/C, the '67 L-79 aluminum intake just used an ordinary steel square-head NPT pipe plug; the iron-intake base 300hp engine used the same plug.
Old Apr 27, 2018 | 09:22 PM
tubman's Avatar
tubman
I would have liked it to be something more "exotic, but it is what it is. Mine looks just like the ones in the pictures.
Thank you, John
To Manifold pipe plug
