Hi guys. I'm up in Seattle (rain) helping a friend rebuild his engine. He thought it was a 350 but the casting number says different. 391660 in Mortec says it's a 68 327. My question is this; the threaded hole in the block in front of the fuel pump rod is not there, it's just a cast solid. When did GM stop/start drilling this?
As you may already know, there is no functional difference between the block of a '68 327 and the block of a '68 350. Both had large-journal mains and a 4" bore, but the 350 crank had a longer stroke.
So, if your friend doesn't mind buying a new or used 350 crank, that engine could become a 350. Note that the pistons would also have to be changed if your friend wasn't already planning to replace them.
