[C2] Help finding Headers
Old May 10, 2018 | 08:28 PM
macs65's Avatar
macs65
Default Help finding Headers
I am putting a 383 Stroker in my 65 with a TKO 600. I ordered a set of Patriot Headers H8025. I what mid length so I can run an exhaust under the car with elec cut outs to my side pipes. Problem is these headers will not fit a standard trans car. Contacted Patriot and Doug's, no mid length headers available for this application.
Has anyone else dealt with this issue and how was it resolved???
Old May 10, 2018 | 09:27 PM
Hitch's Avatar
Hitch
Have you looked at Headmans?
Old May 10, 2018 | 11:54 PM
DONR's Avatar
DONR
Veteran: Marine Corps
Default Headers
I to installed a 383 and a tremec in my 66. I used Sanderson shorty Headers. They dump out where you can route right over to your side pipe. I have thought about putting cut-outs and a secondary exhaust system as well, but now that I have driven mine with the Tremec 5-speed I am not sure I will do that. My side pipes are a lot quieter now going down the highway at 70 miles an hour in 5th gear. I am now running less than 2,000rpm at that speed. I did change out my rear end gears to 373 gears though.
Hope this helps you.
Old May 11, 2018 | 12:42 PM
macs65's Avatar
macs65
Thanks would you happen to recall the Sanderson part number????
To Help finding Headers
