[C2] Wiper motor issues
Old May 15, 2018 | 09:26 AM
tikiwagon's Avatar
tikiwagon
Default Wiper motor issues
Hi the wiper motor on my 63 is playing up again, It sometimes works and then does not turn off at all so i often have to pull the wires off it, I put a new switch in awhile ago but that made no difference and cleaned all contacts even took the top part off and cleaned and re lubed the gears that i can get at and replaced the washer bellows etc( worked for awhile but back to square one again) What is the best to find any faults or am i better getting a recon from one of the vendors as all my attempts have not worked, If that is the case how easy/difficult is it replacing one as looks like half the dash needs to come out(not like a full size chevy where they mount just under the windshield)
I need to get this sorted as living in England we get a lot of rain, tried rainex but only a temp fix
Old May 15, 2018 | 10:13 AM
Jackfit's Avatar
Jackfit
Hi, common problem. Temporary just tap motor with small hammer or metal object to release idle mechanisms. Go to U tube for 1963 wipers video and you will see it. You need to take off 4 screws ( holds washer motor) to see . Dirt and old grease in mechanical part.
U tube 1963 wipers part 1 2 3 4. Part 3 shows it at 3:00 minutes
Jack
Old May 16, 2018 | 02:26 AM
tikiwagon's Avatar
tikiwagon
Thanks I did try this and seemed to work for while but back to not working again with either not working at all or not stopping!
Old May 17, 2018 | 04:38 PM
tikiwagon's Avatar
tikiwagon
Any more ideas?
thanks
Old May 17, 2018 | 04:53 PM
67's's Avatar
67's
Check the ground tab. They won't shut off if you have a bad ground.
Good luck
Tom M
Old May 17, 2018 | 06:18 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Go to Detroit Speed and buy a new wiper motor and don’t look back!
Old May 22, 2018 | 02:49 PM
tikiwagon's Avatar
tikiwagon
Had a look at them and they look good, Are they a simple bolt in and no cutting etc as the car is a very original low mileage one and i dont want to ruin it, also does it work using the old switch in same location, they seem expensive but a recon motor is a lot too! Thanks
Old May 22, 2018 | 02:54 PM
Jackfit's Avatar
Jackfit
The problem is with the idle mechanism . Have you cleaned the parts and the contacts.....if it works sometimes....that means it is not broken, but needs..to be cleaned in the right areas...
As the Utube shows...the mechanism clicking into place....you must make sure that it is free to move and the contacts just above it are clean....
....or take it to Andre......he or his sons will fix it....
Jack
Old May 22, 2018 | 03:23 PM
tikiwagon's Avatar
tikiwagon
I will re strip and clean it again tomorrow and see what happens
Old May 22, 2018 | 11:16 PM
firstgear's Avatar
firstgear
St. Jude Donor '15
Go to Detroit Speed website and look for the installation instructions then you can judge for yourself.
Old May 25, 2018 | 03:36 PM
tikiwagon's Avatar
tikiwagon
Thanks for all the help i stripped and cleaned and re lubed the motor and checked grounds and all seems to be working properly hope this cures it i was thinking about getting a recon motor so that saved me a lot of money
To Wiper motor issues
