[C2] Headlight Bucket (repop)
How good do the repop headlight buckets fit? My original one has a few broken tabs and was I thinking of buying a repop but wondered about the fitment.
I have a pair of reproduction headlight buckets ( the zinc die-cast type ) and they did need a fair amount of filling and sanding to match the contours of the body. Cant compare them to the originals as I never had them, but doubt the factory would of done any bodywork to them.
Absolutely correct, there are plenty of good originals around, and even if you pay more for a good original, you will be hours and/or dollars ahead after installing them.
Gads! How about stating the YEAR bucket you need - 63s are unique and fiberglass...?
Just my opinion, but any replacement bucket will likely need "work" to fit up. That said, some of the "new" ones do have a rough finish requiring lots of extra work on an area that should be smooth.
I found the fit o.k, just needed a bit of filler to smooth out some slight imperfections and fit the contours perfect .Certainly not hours, maybe an hour or so for an experienced repairer.
