'66 L79 engine pretty much stock with a QF carb and Pertronix.
About 6 weeks ago the engine was running great and I did the annual oil change (Rotella) and when I started up the engine to back it off the ramps, I heard a metal on metal scraping sound. I looked in the engine bay where it was clearly coming from but couldn't pinpoint the source. I moved it back into its normal spot in my garage but I didn't have time to pursue it right away.
Over the past couple weeks here is what I've done to locate the problem which seems to be coming from the front passenger side of the engine, without success.
- removed the 2 belts, fan and water pump pulley to eliminate them spinning. Still had the noise
- removed the right side valve cover to check for a loose rocker; all were tight
- removed the fuel pump, plate and rod; rod and pump are both good
This past weekend, I put the fuel pump back on and tried to start it (fuel is getting to carb), but it now won't start (the last time I started it last week for a minute, it ran rough).
I'm now thinking I may have a problem with the timing chain.
I'd like to have your thoughts and ideas on this as well as ask if I can pull off the timing cover without pulling the engine.
I would do the same things your doing. Try to pinpoint the noise by isolating one component at a time - simple to difficult.
It would make sense that a timing chain could be a problem as the sudden stop of the engine when you shut it off could have shucked some of the cam gear.
You could also pull the rocker covers and inspect the rocker arm movement
Yes but you need to pull the oil pan to do it right. Before doing that I would check the timing to make sure its the timing chain. I don't think the noise would be coming from the chain.
A mechanic's stethoscope should be in every toolbox or a short length of rubber garden hose to isolate the sound...
My sister's '71 Pontiac 350 LeMans had a timing chain jump a tooth mysteriously years ago. She pulled up in our Dad's driveway, shut the car down and it wouldn't start back up. Brother and I swapped it out the next day...
If I thought it was the timing chain or valve train causing the noise the first thing I would do is pull the distributor cap and check for rotation and rotor alignment. Then I would pull the valve covers to check rocker movement.
My 1st guess is that while changing the oil/filter, you bumped the flywheel cover and it is scraping on the flywheel? Very common problem with the original design covers.
Also, it's possible that the scraping noise is not related to the way the engine started running after a while.
Absolutely worth checking and an easy fix -- happened to me on a '67 Chevelle not that long ago...
If your final diagnosis leads to pulling the timing cover you may find a nylon cam timing gear decided to fail. You stated having a 67 replacement block, not sure when the nylon gears started appearing and when they were discontinued. I am hoping for something else simple, like the flywheel cover already mentioned.
Before you go to all the trouble to pull the timing cover, roll the engine to TDC on #6 cyl. Both rockers on #1 cyl should be slightly depressed about an equal amount. Exhaust almost closed and intake starting to open. If that's what you see, the timing chain is not your problem.
I used a length of pipe but still couldn't pinpoint it.
A good friend and I discussed this as a potential cause this weekend.
You knocked the front cover back and its now hitting the crank flange.
I had a '54 Corvette with a Muncie/L79 conversion that was done in the mid 60s. That motor was never touched until I checked the timing chain some years later due to what ended up being an issue with a broken valve spring. The timing gear was nylon, not steel.
