Vacuum
Old May 31, 2018 | 12:33 AM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Default Vacuum
Thinking about changing cam.
How much vacuum does a 427-400 horse motor make?
Old May 31, 2018 | 10:04 AM
SWCDuke's Avatar
SWCDuke
Manual trans idling in neutral around 15" @ 600. That's a very good cam... an excellent combination of low end torque and top end power... closer to the SB L-79 cam than the base engine "300 HP" cam.
If you want "more power" and revs you are better off massaging the heads, which will accomplish that objective with no effect on idle behavior and low end torque.
You should check your idle vacuum to see if it is near the above. If not, it probably doesn't have an OE equivalent cam.
Duke
