I am in the process of installing the engine and m20 back into my 67. both have been rebuilt. I am running into an issue with the output shaft yoke not going in far enough. It goes in about 1 5/8".
Wondering if someone knows what I can check? The person who built the trans is closed for the weekend and am hoping to get it going by saturday or sunday.
John
Your tail shaft bushing might have an undersized bore. It happens every so often. If you're brave enough to pull the tail shaft housing off you can check it by trying to put the yoke in the bare housing. You can check the splines on the tail shaft as well.
If you talking about the driveshaft yoke not going all the way in, that's a common problem. The seam on the tailshaft bushing needs to have the high spots removed before installation or this problem will rear it's ugly head. I always check the yolk fitment after installing in the bushing prior to assembling the transmission. I recently bought a brand new Tremec TKO 600 that had the same problem. Fortunately, even though they only have a 90 warranty and it was well over a year later as this was a custom build, Tremec paid to have the bushing replaced.
Another cause could be twisted splines on the shaft but I've only seen that on BW T-10's
Yes. that is what is happening. Do you think I need to remove the trans from the car and bring it back to the builder?
If the bushing is the issue, there's a special tool that allows the bushing to be removed without removing or dis-assembling the transmission. Maybe your trans. builder has access to one and it can be replaced while still in the car. I know this doesn't help you for this week-end but it beats pulling the trans.
Ok. Thanks for the advice. I will wait until I hear from him on Monday.
If the tranny is out of the car, and you feel like you want to take the tail off here’s how you do it.
Put the tranny in reverse. (Shift lever forward)
Flip trans over, drive out shift shaft retaining pin. (Bottom to top)
Unbolt 6? Bolts noting length.
Pull shift lever out.
Tail comes off.
If your worried about the gasket/tear it up, pm your address I’ll send you one free.
Think of a car with parallel leaf rear springs. Like an early Camaro. The front spring mount is fixed. The rear spring mount is mounted on a hinge shackle. When the rear wheel goes up and down it causes the rear axle to travel in an arc. When it does the drive shaft must lengthen and shorten. Thus the need for a slip yoke to allow for this change. It should slide in and out freely. Hope that helps.
This is a Corvette. Only temp expansion and contraction move the yoke.
