[C2] Power Brake Question - 65 Coupe
I’m in the middle of a restoration and currently installing the brake system. When I purchased the car it had a stock style power brake booster installed but no proportional valve. Does the car need one?
The brake lines that I ordered specific for the car going to the master are a different fitting than the opening in the master cylinder.
wondering if I need the proportional valve or
just find an adapter fitting that will work.
Anything I find is telling me only the 67 had the proportional valve.
thanks!
thanks!
thanks!
thanks!
If your master cylinder is not a DELCO original unit, it may take different connections. NAPA and others sell conversion connectors/adapters.
Larry
Which brake lines did you buy? It sounds like you may have gotten the wrong line set.
66 was the beginning of 1/4" brake lines.
