66 Posi Question
66 Posi Question
The previous owner stated that my 66 has a 3.55:1 posi. While adjusting the parking brakes and with the car on jack stands, when I rotated the drivers side wheel the passengers side rotated in the same direction. I had thought that on a posi, it would rotate in an opposite direction. Is that the case? Must confess, the mechanics of differentials is knowledge I do not yet possess but this would be a start.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks.
In 1966 Positraction was a $42.15 option (G81), ordered on 86% of all corvettes. Yours was either one of the almost 14% in which it wasn't ordered or has been changed out at some point. The 3:55 was only available as an option on the SB with the L79 or standard on the BB, L72, where it was only available with the posi. It's not clear if it was available without the posi in the L79.
If your car is not equipped with the L79 or an L72, and it has a 3:55 ratio, it is very likely it was changed out at some time. Before you jump to too many conclusions, you may want to first verify the ratio is in fact a 3:55.
Check out pages 12 and 18 at this link. https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
I have crawled under her and the differential has the AN designation which I believe is correct for a posi. She does have (or is supposed to have) the L-79 motor (has the HT designation stamped on the block although it is hard for me to make out "broach marks" on the stamping. I will check out your link. I have not done the spin the wheel 360 degrees while counting driveshaft revolutions yet, plan to do that soon. While I am at it I will check to see if as I hold one wheel, the other is locked up. Thanks
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
look at page 12 PDF and page 68 of the document for the rear end codes. they say the location is rt front of carrier and it lists as 396. interesting. maybe they carried some info over from 65. my early 66 L72 has the code and date on the bottom, back by the rear cover and is " AZ 09 21 65"
Gusto
The AMA Specifications issued 2-22-65 (page 74 of 99) are the first mention of the 396 (L78).
GUSTO
