Engine numbers help please
Old Jul 3, 2018 | 11:10 AM
Oaker57's Avatar
Oaker57
Default Engine numbers help please
Trying to help a friend out who just picked up a 63 roadster, and has an engine block with F0409RE on the pad.
Can anyone please decipher what motor this is, as it's obviously not the original.
Thanks in adavance.....
Old Jul 3, 2018 | 11:30 AM
Panama 58's Avatar
Panama 58
Not knowing the casting date or casting number on the block, here's what I know: F (Flint cast) 0409 (April, 9th engine assembly date) RE is for a 1962, 327, manual transmission, hi performance 340 horse, 4 bbl. for Corvette. The casting date is located on the top, rear portion of the block near the distributor. This will be where you will know the actual casting date of the block and correlation to the assembly date of the engine.
Old Jul 3, 2018 | 11:52 AM
Oaker57's Avatar
Oaker57
Thank you sir, I don't have the casting date handy, but the VIN number tells me it was a March 63 build date, but VIN on engine pad does not match. So I'm guessing it's possible that this is year correct but not numbers matching motor. Coincidently it does have 340 stickers on the valve covers, and a high HP tach.
Old Jul 3, 2018 | 11:55 AM
Critter1's Avatar
Critter1
The stamped RE characters were used for 62, 63 and 64. They indicate a solid lifter 340 Hp for 62 and 63 and a 365 HP for 64.
Old Jul 3, 2018 | 11:57 AM
Rumblegutz's Avatar
Rumblegutz
Why do you feel it is obviously not the original engine?
The RE suffix was used in 1962, 1963 and 1964 for the solid lifter 327 with 340hp in '62-3 and 365hp for '64.
Old Jul 3, 2018 | 12:00 PM
Oaker57's Avatar
Oaker57
I will have to get the casting number, but already know that the VIN doesn't match the pad numbers, the pad number is 4115902. Again that doesn't match the cars VIN.
Old Jul 3, 2018 | 12:37 PM
rsinor's Avatar
rsinor
So if it is not a re stamp this is a 365HP engine block out of 1964 #15902
Old Jul 3, 2018 | 12:54 PM
Oaker57's Avatar
Oaker57
I thought RE was for a 340 HP....??
Old Jul 3, 2018 | 01:23 PM
Critter1's Avatar
Critter1
As mentioned above, the RE code is used for 62, 63 and 64. 62 and 63 were 340 HP and 64 was 365 HP. Same RE code though.
Old Jul 3, 2018 | 03:15 PM
Oaker57's Avatar
Oaker57
Ok now it makes sense, thank you.
Old Jul 3, 2018 | 04:05 PM
Panama 58's Avatar
Panama 58
This is why we need to know what the casting date.
Old Jul 3, 2018 | 05:09 PM
emccomas's Avatar
emccomas
1964 Corvette #15902 (coupe or convertible) does NOT show up in NMVTIS.
Old Jul 3, 2018 | 06:00 PM
Panama 58's Avatar
Panama 58
Not listed in the C2 Registry either.
To Engine numbers help please
