Re-clock the heat riser
Old Jul 5, 2018 | 11:28 AM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Default Re-clock the heat riser
My heat riser is not oriented correctly. I removed two of the nuts and one came out with the stud. The exhaust header pipe doesn't want to drop enough to clear the studs. What is the easiest way?
Old Jul 5, 2018 | 11:31 AM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Try removing the clamp at the transmission crossmember. That might give you the slack you need, but I doubt it. The only other alternative is to try and remove the other 2 studs (not easy--they're usually seized in there) or remove the exhaust manifold bolts and lift the manifold for clearance.
RON
Old Jul 5, 2018 | 11:33 AM
MikeM's Avatar
MikeM
You own a pry bar?
Old Jul 5, 2018 | 11:40 AM
rongold's Avatar
rongold
Originally Posted by MikeM
You own a pry bar?
I don't think the hole in the crossmember is big enough to get the pipe down far enough to slide the heat riser off of the studs, Mike.
RON
Old Jul 5, 2018 | 12:30 PM
Redbird's Avatar
Redbird
Thank you both! I loosened the clamp and gained a little wiggle room and pried down on the pipe. The heat riser is now soaking in Evaporust overnight. It was a little frozen up from being installed wrong by prior owner. I am a true believer in this stuff. Thank you again guys.
To Re-clock the heat riser
