Let me throw one more log on the fire! Some pin locations are off set and not in the center of the piston. In that case the left and right side must be installed correctly.
Dom
Offset pins reduce piston slap. Most cast pistons have offset pins but many high performance pistons have on center pins.
Ever wonder why when Chevy put the valve reliefs in the SBC pistons, they put in four reliefs for two valves on the flat top pistons?
Mike,
Used to be only 2 valve reliefs on the SB pistons and a F on each piston. Those days are gone.
ALSO all SB pistons weighed the same, dish, flat top, and domed! Won lots of bets on that. Also were the BB pistons back then. Cranks were balanced for all pistons used. I think it was 602 grams.
Now piston sets are within 50 grams of factory.
Boy at speed shop says that lighter pistons are high perf. He had to be a great grandson of the old mechanics
Seems I remember the early 283 domed FI pistons weighed more than the the flat top pistons and therefore, there was a special crank released in service to account for the weight difference? Or, it could have been the '61 forged FI pistons that had the huge dome on them. Don't remember.
I think 265 and/or early 283 flat tops had only two valve reliefs. Don't remember. Been too long ago. Memory is a terrible thing to lose.
Your thoughts?
PS. I also know that I replaced one piston in my 260/350 Mercruiser engine with a TRW replacement and the replacement was much heavier than the OEM Mercruiser. Right on top of July 4th weekend so no time to balance the piston and in it went.
Mike,
Back in the days of old I had every SB engine and parts in the shop. Still have 265's and 283's + a bunch of 327's, not to mention some BB 396,427,and 454's. The 350's don't count much in the shop because they are a dime a dozen with exception to the forged cranks. I have a gram scale and weighed rods, pistons, and pins. In the last 30 years when I bought piston sets they were all over the place. The sets (8) were all the same but the heavy sets meant BALANCE shop. On the ones that were lighter than stock, I loaded the wrist pin with weight that I pressed into the hole, worked great, AND on my Mercruiser also.
I have to check weights on all the aircraft engines I rebuild. Nothing required there because the cranks are O. what ever yoy put on one side of the journal has to match the other! Can have 3 different opposing weight sets as long as each weight set is on the same crank journal.
John, I was not aware GM did any Piston machining? I thought TRW gave GM a finished product ready to install.
Nope. The engine plants machined their own pistons from blanks - in the 60's, one bore size (like 4") could have as many as (8) sub-sizes, all within production specifications. It was possible for one block to have (8) different air-gaged sizes, with the code for that size stamped on the pan rail. Each block's (8) stamp codes (one for each bore) were transmitted electronically from the air-gage station at the beginning of the assembly line to the piston department, which machined, ringed, and installed the rod for each bore, and sent a tray with that block's piston/ring/rod set on an overhead conveyor to the assembly line, where the piston/ring/rod set was "stuffed" into the block the air-gage measurements came from. In the engine plants, pistons were machined to match the bores.
Suppliers like TRW and others provided pre-machined pistons to GM for Service, individually and in packs of (8), all machined to the same size. In Service, the bore diameters were honed to match the purchased finished pistons.
The offset pins were used on many engine designs as stated to help reduce piston slap.
I knew Drag racers in the Stock NHRA classes that reversed the pistons and ran the offset pin on the inside rather than the outside of the bore. They claimed the engines would RPM better set up this way.
I never saw any engineering to support that thought but the guys I knew playing that game were winning and had class records. A, B and C Stock running Dodge engines.
I think I posted this before, but here's an article I wrote about ten years ago on the complete Flint V-8 process for "castings in - engines out at 300 per hour); with luck, the uploader will accept it. If not, PM me with your e-mail address and I'll e-mail it to you.
Thanks John. Very interesting. I've never been to the Flint engine plant.
JohnZ ,
Your engine build article uploaded great for me.
Do you still have the next file on the Corvette Plant engine dress out that you mentioned in the last sentence of the article? I would love to have that if available. Please post or send to me through PM.
Thanks,
Dennis
Reason: email put on in error
JohnZ ,
Thanks,
Dennis
Here's the followup article on the Engine Dress Line at St. Louis-Corvette.
John do you have a master list of all your articles on line anywhere. I know there are a few on the CRG. Would you mind if I get a friend of mine to put them on his Chevelle stuff.net web site The ones that pertains to both? They are great reads and would be great to help others
