[C2] front end support
Old Aug 6, 2018 | 07:34 PM
blap's Avatar
blap
Default front end support
What area holds or supports the majority of the weight of the nose on a c2 vette
There is no ft body mount if you will ,so its glued in place and connected to the rad support?
Or is it that all the joints and pieces glued together gives it strength .
Old Aug 6, 2018 | 08:54 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
The radiator core support is bolted to the front frame horns, with shims, and is the tie in location for front end support rods, and the front fenders are bolted to the core support. The radiator support is a sturdy piece that is heavier than required just to hold the radiator. The front bumpers are supported by the bumper supports that bolt to the frame.
Old Aug 6, 2018 | 09:01 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Your last sentence is your answer. Along with the radiator core support as it's bolted horizontally with an angular brace to the front frame horn and vertically at the sides. Dennis
Old Aug 6, 2018 | 09:06 PM
pop23235's Avatar
pop23235
There are also two rods from the radiator support to the headlight framing which includes the inner headlight pivot support and the large lateral steel member just in front of the hood. But the weight is on the rods.
Old Aug 7, 2018 | 06:51 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
The radiator core support ties things together and firms up the front as stated...its bolted in and shimmed... The support configuration varies between years - a 63 only support is shown:
Old Aug 7, 2018 | 08:02 AM
blap's Avatar
blap
Thank you all for replying !
Old Aug 7, 2018 | 11:29 AM
blap's Avatar
blap
So if the thickness of the shims are changed what gap or height will be adjusted
Old Aug 7, 2018 | 12:04 PM
Bluestripe67
My '67 only had shims on the vertical attachment points. Decrease or increase would change the hood to fender gap I think, but it would be one hell of an effort. I suspect that the moulding of panels varied some and the bonding the different sections varied some. When the rad support was installed I guess the line assembler looked for the gap and installed the appropriate number of shims. Yes, no maybe? Dennis
Old Aug 7, 2018 | 12:15 PM
pop23235's Avatar
pop23235
I would not expect any gaps to be changed as you are moving the anchor point up or down for all the front end supports.
Old Aug 8, 2018 | 11:48 AM
JohnZ's Avatar
JohnZ
Yup. When the radiator support was loaded into the front clip (before the front clip was bonded to the firewall), the operator "stuff-shimmed" the side attachments to the inner fenders as required.
To front end support
