Intake Manifold Pattern Numbers
Old Aug 6, 2018 | 08:00 PM
ettev's Avatar
ettev
Default Intake Manifold Pattern Numbers
So out of years-long storage I dug out a 3782783 manifold I’d like to use on a project. The pattern number is “GM2”. I’ve seen these manifolds with both a “GM1” and this “GM2” designation cast into them. What’s the functional or application difference between these pattern number parts/castings?
Old Aug 6, 2018 | 08:11 PM
Vette5311's Avatar
Vette5311
Can you post a picture?
Old Aug 6, 2018 | 08:12 PM
ettev's Avatar
ettev
Old Aug 6, 2018 | 08:16 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
simple it took a lot of sand molds to keep up with production of a very common used part
Old Aug 6, 2018 | 08:51 PM
ettev's Avatar
ettev
Casting date is K 2 5 (November 2, 1965?).
Old Aug 6, 2018 | 09:10 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
The GMX, where X = a number from 1 to ?? that indicates the individual pattern sequence number for a serialized part (like your manifold). It means nothing, in other words.
That is as I understand it. It has nothing to do with the casting date. I have four abc heads with the GM pattern numbers of 1, 2, 5, and 7, IIRC.
Old Aug 6, 2018 | 09:14 PM
ettev's Avatar
ettev
Ok thanks.
To Intake Manifold Pattern Numbers
