swapping blocks
Old Aug 16, 2018 | 08:08 PM
Roger Walling's Avatar
Roger Walling
Default swapping blocks
I have a 350 with a cracked water jacket.
This engine has just been rebuilt and I am wondering if I could just swap all components into the new block, bearings and all (with new rings)
It might not be the best way but I am trying to keep the cost down to the minimum for a quick new project.
Old Aug 16, 2018 | 08:48 PM
R66's Avatar
R66
Bearings have a crush when the torque is applied on the main caps. I would not try to reuse them as the main bearing bore on one block to another may vary and the cost of new bearings is not that great.
Reusing the rod bearings on the same rod and crank location should not poise a problem. I would still plastigage them on reinstallation.
Rings - how many miles before the cracked block?? More than 50, I would not try it. They probably have worn to fit the bore which may not be the same as the new block bore.
Cam, lifters, pushrods, etc. I would swap them out as long as the lifter position on the cam is not altered. New cam bearings of course.
Heads - no problem, unless they contributed to the split cylinder.
Old Aug 16, 2018 | 10:45 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
If it's just an external crack , then get it welded up. As far as swapping things over---Hey, it's a Chevy. Back when I had no money, I would do stuff like that and it would live a long time. keep everything clean and IN ORDER.
Old Aug 16, 2018 | 11:41 PM
Robert61's Avatar
Robert61
I think this is called engine roulette. 1. I would not reuse bearings unless they are perfect. 2 swapping lifters from one block to another you may as well dump them all in a box and.pull them back out one at a time. Maybe just maybe if both blocks were blueprinted you might get away with it but by swapping blocks the location and break in patterns are going to be different. 3. Rings I would measure the end gap if its below .020" I'd reuse them in a heart beat. So now the question is how lucky do you feel?
Old Aug 17, 2018 | 12:48 AM
John S 1961's Avatar
John S 1961
How sure are you of this diagnosis? Can you describe all the symptoms? Have you pressure tested and personally seen your block leaking? And from where exactly. You could always try block sealers magic sauces. I have seen them work.
Old Aug 17, 2018 | 09:32 AM
MikeM's Avatar
MikeM
I had an engine block crack diagnosed about 600 miles out of the 12k mile warranty. All the factory would do was provide and new block and labor to switch all the parts over from the first engine. That included rings, bearings, cam, lifters, pistons/rods.
It ran the same as before.
I wasn't happy with it but that's the deal I was offered. I'd consider that a risky repair.
Old Aug 17, 2018 | 10:08 AM
Vette5311's Avatar
Vette5311
Default Risky
Your playing Russian Roulette with only 2 empty chambers.
Old Aug 17, 2018 | 01:36 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Cracked water jacket? Is that the actual cylinder or the block walls surrounding the cylinders?
Old Aug 17, 2018 | 03:32 PM
Robert61's Avatar
Robert61
Some cracks are repairable with a stich repair. Externally is a lot easier and more likely to be repairable. Some internal cracks can be repaired. You CAN NOT repair it by welding. There is a process for welding cast iron but it has to be heated cherry red and every surface will coke over from carbon coming to the surface. And everything would need to be remachined. Just not worth it.
Old Aug 17, 2018 | 03:39 PM
Roger Walling
The crack is on the exterior of the block and it runs into a core plug hole.
I has sandblasted it and applied fiberglass over the crack, but I think it is leaking right at the hole where the plug makes contact.
I am going to try a rubber plug with a flexible bonding agent first.
Old Aug 17, 2018 | 05:36 PM
Bill Pilon's Avatar
Bill Pilon
It can be repaired using a tapered method.
Bill
Old Aug 17, 2018 | 08:32 PM
cardo0's Avatar
cardo0
Well if you don't want to have it welded then you could have it brazed or brass welded shut. It does need to be ground out enough for brass filler to fill the crack completely. Don't know how to handle the freeze plug hole though and that could be tricky. But that area is not really a stressful or load bearing area and should be repairable. Much easier than replacing the block.
Old Aug 17, 2018 | 08:55 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Bill
Agreed. Irontite makes the cast iron, tapered plugs and tapered tap for this purpose. Repaired many Model A blocks this way.
We called it “stitching”. Also used the plugs for cylinder head repairs.
The plugs are made in both cast iron and aluminum. In the OP’s case cast iron would be the material to use.
Old Aug 17, 2018 | 10:40 PM
Robert61's Avatar
Robert61
You can purchase the kit to do this your self. And there's nothing to it. Just drill tap install the tapered plug. On a crack I don't like to screw the plug in until it snaps off. Score it and let it snap. Then install the next plug. When you get to the freeze plug hole let it over lap and finish the hole with a air grinder then JB weld the hole and install the freeze plug. It will be a permanent repair. If you need more info pm me.
Old Aug 18, 2018 | 10:30 PM
domenic tallarita's Avatar
domenic tallarita
GM did fit each piston to bore. #'s were stamped on pan surface of block. if you saw a 12 that would be .0012 and not cylinder #12. I believe the #'s were in tenths of thousants.
Dom
Old Aug 19, 2018 | 04:58 PM
BADBIRDCAGE
Dom
they fit/supplied piston, wrist pin, piston ring assemblies in what we referred to as “builder blocks” in the old days. A bare block gave you finished bores at standard and camshaft bearings installed.
Old Aug 19, 2018 | 06:37 PM
domenic tallarita
Actually there was quality controll @ GM, which Chysler didn't do . Fit the pistons to the bore. GM, If I understood what you were saying , did fit each piston to bore.
We did a bunch of 413 Dodge engines that had piston slap. Chysler said it was cheaper to replace the engine than employ quality controll. Every short GM block I replaced was piston fitted to block. NOW that was in 1971!
Dom
To swapping blocks
Old Aug 19, 2018 | 07:07 PM
BADBIRDCAGE
Dom
Dom
We are talking the same era. I was in the automotive machine shop business from 1969 through 1981.
No factory piston fitting on a replacement “bare block” as it came without internals. You got a block with cylinder bores finished to standard, camshaft bearings installed and main caps torqued in place. Ready for assembly with your parts after inspection.
“Builder blocks” (as we called them) were supplied from Chevrolet with piston/wrist pin/ring assemblies in the bores and you had to remove them from the cylinders and attach them to your connecting rods. Then you assembled the rest of the engine.
Short blocks were assemblies lacking cylinder heads, timing covers and oil pans. Had crankshaft, connecting rods, pistons, rings, rear main seal, camshaft, timing chain and sprockets. I don’t remember if the oil pump and intermediate shaft was supplied or not. If it was you had to install it.
In 1982 I decided I wanted to eat regularly and left the trade for a different “career”. Good move on my part as the trade didn’t reward you financially as it does today.
Old Aug 19, 2018 | 08:16 PM
MikeM's Avatar
MikeM
What you're calling"builder blocks", GM called, "fitted blocks" and the pistons were custom fitted to the finished bore of the block. No rods, no crankshaft.
If I remember right (and I might not) GM also supplied various sized standard and over sized pistons as listed in the parts book. As in various sizes of standard, various sizes of .010 OS and etc.
I believe they may have custom fit crankshaft main bearings as well.
MoPar at one time used to send new engines out of the engine plant with undersize crankshaft journals. Engine like this had an extra digit added to the engine ID type.
Old Aug 19, 2018 | 09:45 PM
BADBIRDCAGE
Thanks Mike. I had forgotten the “fitted” term but that is it.
On Corvairs, VWs and Porsches we called the replacement cylinder assemblies jugs and slugs.
