R & R fuel tank sending unit.
One thing I found helpful is to lightly grease the metal-on-metal camming surfaces of the locking ring/gas tank fitting. This area can bind-up a bit during assembly even when using the proper tool.
Phil
Phil
GM did indeed use engine oil and Quanta recommends it as well when replacing the sending unit. Here's a previous thread on the subject for the non-believers - https://www.corvetteforum.com/forums...ding-unit.html
Repo. seals work perfectly IF they are installed correctly.
JohnZ states - "In the plant, we kept the fat rubber O-ring seals in a tray of motor oil for several hours before installing them; the requirement to do that is in the Assembly Manual, in the "Lubricants" section that decodes the lube symbol on the sheet that shows the installation."
I agree both O-rings can be made to work......maybe there is more than one repro vendor because mine was not sealing; even after 1/2 day in a coffee cup of oil...
Good to know - too bad they didn't include that in the GM shop manuals for the poor field tech ....
JohnZ has been instructing us about the o-rings and "the bucket of engine oil" for about 15 years now..........ever since I have been on the forum. But it is good to repeat for all.
Larry
What can I say ?
I followed the shop manual procedure using good parts and was successful; as did prob 20 million mechanics over the years...
I think that about covers it...
Yes..........there is more than one vendor for the gaskets. The best one I have seen recently is made/sold (last few years) by OEM Reproductions, and is now the one sold by many of our parts suppliers. The ring and the cam lock supplied with my Quanta tank 5 years ago were both not very good, and were immediately thrown away.
Larry
Larry
Did you mean OER reproductions? I'm not finding much under OEM Reproductions.
colo63sw (02-04-2019)
Thanks again.
Larry
Dr Rebuild site has how to identify this GM o-ring by the embossed logo. Here is the link: https://shop.docrebuild.com/1963-197...825206NOS.aspx
I knew this but could not immediately remember the correct logo without going to the garage. Then I remembered the Dr has it on his webpage.
Enjoy.
Larry
Enjoy.
Larry
Enjoy.
Larry
Enjoy.
Larry
This will get interesting. I have now seem NOS prices for the O-ring from $3 to $25.
Thanks again, I really appreciate it!
