[C2] Need to remove tach cable
Old Aug 23, 2018 | 12:20 AM
TJefferson2020's Avatar
TJefferson2020
Default Need to remove tach cable
Need to pull cable, lube and replace. Can I pull the whole thing out through the fire wall into the engine bay?
Old Aug 23, 2018 | 08:45 AM
jrm5657's Avatar
jrm5657
2022 C2 of the Year Finalist - Modified
Not sure what year you are working on, but if it is a midyear, the answer is no. The cable goes in the casing from the tachometer end, not the distributor end. You should be able to unscrew the casing from both ends and pull the inner cable out and clean and lube. It is not much fun getting to the back of the tach, but it can be done.
Old Aug 23, 2018 | 09:08 AM
TJefferson2020
64. Sorry.
I do do seem to remember the tach cable gets shoved through the firewall from the inside out. Much tougher with the car put together. I can get my hand to the rear of the tach but super hard to get leverage (and I’m not as good at standing on my head these days....)
tach stopped working. It’s rebuilt so I know it’s the cable. It was acting erratically just like a cable run out of lube. Then, nothin’.
im going to pull it, clean it and lube with graphite. Or buy anew one. I seem to recall they are cheap. I like my tach working!
Old Aug 23, 2018 | 10:47 AM
jrm5657's Avatar
jrm5657
Yes, it is a pain to get unscrewed. Just FYI, I recently had to remove a dash cluster because the POS plastic tip on the tach cable had broke off in the tachometer. Needless to say, I was not going to install a new cable with the same plastic tip, so I went to local speedometer repair shop and had them make me a new cable which has the swaged metal tip like originals. Also did speedometer cable at the same time since I had easy access to it.
Old Aug 23, 2018 | 03:59 PM
Donald #31176's Avatar
Donald #31176
Originally Posted by Snorkie
64. Sorry.
Before you condemn the cable you might check the distributor tach drive gear . Unscrew the brass couple to check the drive gear. If the gear is bad you might also want to check the mainshaft gear on the distributor as when one gear goes bad the other probably is bad too.
To Need to remove tach cable
