c2 posi additive
Old Aug 23, 2018 | 02:10 PM
ndsman's Avatar
ndsman
4th Gear
Default c2 posi additive
c2 with a posi added bottle or additive not working, can I add another without damage?
Old Aug 23, 2018 | 04:56 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Wrong Forum, but yes, a second bottle of posi lube can be added. Do some figure 8's to work it into the clutches.
Old Aug 24, 2018 | 08:17 AM
ndsman's Avatar
ndsman
4th Gear
Thank You for the jnfo.
Old Aug 24, 2018 | 10:03 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
My Eaton posi is running with two bottles - and yes figure 8's in an empty parking lot....
More posi fluid won't fix worn clutches though - don't expect miracles in that case...
Old Aug 24, 2018 | 10:25 AM
ndsman's Avatar
ndsman
4th Gear
Default posi
Thanks. In storage 15 years fresh fluid ran great before.
Old Aug 24, 2018 | 01:58 PM
GTR1999's Avatar
GTR1999
Always use 2 bottles of the current GM additive and a good gear oil, 90 or 85/140. You can look at the new slick oils but you do not need them. Do the figure 8's and that should cover it - if not then the posi needs work. If you have a 63-64 original DANA posi that is a whole different deal.
Old Aug 24, 2018 | 02:26 PM
ndsman's Avatar
ndsman
4th Gear
Thank You. 1966 original rear end. Sat for 15 years. Fresh fluid but only 1 bottle. Thanks again.
To c2 posi additive
