Coolant
Old Aug 28, 2018 | 06:39 AM
Spowell637's Avatar
Spowell637
Default Coolant
I recently purchased a 1966 Roadster with 327 300 hp engine. What is the recommended coolant for this car?
Thanking in advance for any assistance.
Old Aug 28, 2018 | 07:16 AM
66RBS's Avatar
66RBS
Zerex GO5 . It is the most friendly to the older metals ( solder, etc) in your heater core. It is HOAT technology
Old Aug 28, 2018 | 07:40 AM
65GGvert's Avatar
65GGvert
Green
Old Aug 28, 2018 | 10:09 AM
SWCDuke's Avatar
SWCDuke
Mix the full strength G05 50/50 with distilled water. Make sure you remove the block drain plugs under the ignition shields. Look at the nearby thread... heater hose size.
Duke
Old Aug 28, 2018 | 10:27 AM
SoCalErv's Avatar
SoCalErv
Army
Duke
Duke:
So if you have the old Green coolant a complete flush is required to utilize the G05?
Old Aug 28, 2018 | 10:44 AM
SWCDuke's Avatar
SWCDuke
Specifically no, but it depends. If converting from an IAT to OAT the system should be completely drained and thoroughly flushed. It's okay to change from IAT to HOAT without flushing, but one should still drain all the old antifreeze, and the block holds at least 4 quarts. Not draining the block would be like draining out only 3/4 of the old oil for an oil change job.
A through water flush is always optional.
BTW over the years whatever coolant changed were done it's likely that the block drain plugs were never removed. In this case nothing may drain out when they are removed, so you have to dig out all the debris with a sharp tool. If this is the case I recommend a thorough system flush.
Duke
To Coolant
