i am trying to clean smoke damage off of an original back window for a hardtop 1966. its a nos that i had stored at my sisters and her garage caught fire and it has smoke damage now. any suggestions would help. not melted just smoke damage !
Because the rear window is acrylic, you may not be able to save it. The chemicals released in a fire can be acidic and do permanent damage to a lot of surfaces. If you were fortunate enough that it did not warp (or cave in even a little) you may have to sand and polish it like you would to an acrylic headlight that has yellowed. Of course a new rear window is under $400 so it may not be worth the time and effort, particularly if it is damaged on the inside and outside surface.
You might contact the folks at Auto Entec, who restores hardtops and sells the rear window, or Coffman Corvette and see what they recommend to try to restore it. Both are great folks to work with, know these tops intimately and will probably have a solution to the problem.
Plexus is a good plastic window cleaner that polishes as it cleans. I've also used lemon Pledge too. Not sure if they'll be abrasive enough to do the trick, but they might be a start. Good luck
Meguiar's Plast-X Clear Plastic Cleaner and Polish. I've tried many products and this is the best by far. It works great by hand and even better if you use a buffer with a foam pad.
Micromesh sandpaper, you want to get 3000, 4500 and 6000 grit, coupled with a rubbing compound specifically targeted at plexiglass. If you want to make sure you get the right stuff contact GlassWorks and ask for their scratch kit. It has some sandpaper and compound. There won’t be enough in the kit to do an entire rear window.
You can download my book I put together on refurbishing my top. I found a way to slip my screw driver a couple of times when tightening down barrel fasteners. You can download it here...it’s free....it’s more near the rear of the book.
Because the rear window is acrylic, you may not be able to save it. The chemicals released in a fire can be acidic and do permanent damage to a lot of surfaces.....
Good luck... GUSTO
This would be my fear - if the sooty smoke permeated the window, then no amount of polishing may work....I'd try a small test area with Meguiar's or 3M Marine Plastic Restorer (which I have had good luck using) - West Marine or perhaps Bass Pro may have it... You should know pretty quickly if you can salvage the window....if so you can move on to 3M Plastic Polish....
