'65 oil pressure line - Plastic? Bubba been here?
Ok, I peeked under the dash and found a plastic oil pressure line. The line actually had bubbles or air pockets in the line. I purchased an copper oil line from a vendo
r and I'm going to replace it. How do I attach the copper tubing to the brass fittings? Do I use teflon tape? Any suggestions please. Thanks , Sully
Original line is copper coated STEEL. You do not want regular copper.
Larry
Larry
Received 1,920 Likes
Sullyvette (08-31-2018)
Vette5311 (09-02-2018)
2023 Restomod of the Year Finalist
My 65 has plastic, no telling how long it’s been on there. I remember using it on other cars as well without a problem. I would think it would withstand vibration better than steel! Why not plastic?
Sullyvette (09-01-2018)
USMC
Because plastic is petroleum based and hot oil and plastic aren’t a good combo...That’s one of the first things I replaced when I stole my ‘66 from my father.
I had visions of 10W/30 filling my drivers side footwell...
Received 3,043 Likes
St. Jude Donor '05
Most of Autometers kits are copper nothing wrong with it, no teflon needed.
Back in the 60's and 70's if you bought an oil gauge to add to a car that just had a light most came with a plastic hose. Never had any problems with them unless you kinked the hose or let it rest against something that would rub a hole in it.
There is plastic and then there is PLASTIC.................Some plastic tubing was polyethylene and other plastic tubing was nylon. I used the nylon, and it held up well in my older (non-Corvette) cars. But using the polyethylene was not the best idea.
Larry
I drove a 58 Biscayne when in college that had a ticking noise coming from the dash. Drove me crazy, finally narrowed down to the oil pressure gauge. The metal line was transmitting engine noise, oil pump maybe, to the dash. I replaced it with nylon. Not that I would ever recommend that.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I've used the nylon that comes with new gauges for years.....never had a problem. But copper looks more authentic on an old car.
I guess I need to clarify .I call it plastic but it actually was the regular automotive oil line nylon that broke . It will break at the compression fitting if you tighten it too much which was obviously what happened . Why would anyone even attempt to use hardware plastic tubing for that purpose ?
Larry
