Driveline Length
Old Sep 1, 2018 | 02:53 PM
ptjsk's Avatar
ptjsk
Default Driveline Length
Ok Guys,
There's still about 2&3/8ths of an inch inside the transmission.
Do you think this will be ok, or should I extend it 3/4" or so?
Pat
Old Sep 1, 2018 | 04:36 PM
Vette5311's Avatar
Vette5311
Default ? Year
what year car?
Old Sep 1, 2018 | 08:06 PM
ptjsk's Avatar
ptjsk
It's a '63, but the transmission is a super T10. So it has the turbo 400 yoke on it.
Pat
Old Sep 1, 2018 | 08:17 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Call a company that makes drive shafts and chat with them about engagement length.....
Old Sep 1, 2018 | 08:28 PM
firstgear's Avatar
firstgear
St. Jude Donor '15
Here is a discussion I found...
https://www.bangshift.com/forum/foru...ment-is-enough
if you want more info, google “driveshaft yoke engagement”. I think you can find what you are looking for....
Old Sep 1, 2018 | 08:32 PM
1snake's Avatar
1snake
Can't tell from your pic. but if the yolk extends into the transmission far enough to be fully supported by the tail shaft bushing, you're fine. Here's a pic. of how they looked with an original trans. and yolk.
Old Sep 1, 2018 | 08:46 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Are you making any HP ?? Then reason I ask is, that looks like the skinny 2" driveshaft. I just had a new shaft made for my 60 and the shop wanted 1/2 to 3/4" between the yoke and seal. I run my car pretty hard so I went with a 2 3/4" shaft . BTW most of the C-3 shafts I looked at were 2 1/2 "
Old Sep 1, 2018 | 09:05 PM
ptjsk's Avatar
ptjsk
Thanks Jim,
Looks like I should be ok.
Pat
Old Sep 1, 2018 | 09:17 PM
ptjsk's Avatar
ptjsk
Hey Pop,
I'm "hoping" to make some horsepower. Somewhere near 400. It's an original 340 hp car, with the original motor, heads etc. I did remain with a solid cam, but changed the specs a bit to gain some torque a bit sooner than stock. Also, enlarged the valves to the 2.02, unshrouded the chambers, and quite a bit of head work on the flow. So it should be at least 375, and hopefully closer to 400.
But you're right, it is a 2" driveline. And I definitely don't pamper the cars when I drive them!
Pat
Old Sep 1, 2018 | 09:19 PM
ptjsk's Avatar
ptjsk
Hello Herb,
Yes I did contact a local drive shaft company. He thought I would be fine, but I just wanted to hear what you guy's thought.
One of those things, I should leave well enough alone!
Pat
Old Sep 1, 2018 | 10:30 PM
Robert61's Avatar
Robert61
If you lengthen it too much you might not be able to get it in. Looks good to me.
Old Sep 2, 2018 | 10:40 AM
Factoid's Avatar
Factoid
Looks good to me. Remember the C2 differential is fixed so there is little linear movement of the driveshaft.
However, you might want to revisit the diameter (strength) of the driveshaft and ujoints.
Old Sep 2, 2018 | 01:42 PM
Robert61's Avatar
Robert61
I've seen the small diameter drive shafts used in race cars for years. I don't see it as an issue.
Old Sep 2, 2018 | 04:10 PM
Vette5311's Avatar
Vette5311
Default Just depends
on how much power your making and how much bite your getting. I have also seen them twisted like a pretzel.
Old Sep 2, 2018 | 06:46 PM
JohnZ's Avatar
JohnZ
Remember that 250hp Powerglides and 560hp L-88's all used the SAME driveshaft.
If you set it up with too much penetration (inadequate gap between the front of the yoke and the end of the extension housing), you won't be able to remove it unless you pull the body or cut the driveshaft.
Old Sep 2, 2018 | 06:55 PM
ptjsk's Avatar
ptjsk
Thanks John,
Honestly I think I'm getting down into the weeds a little too much! At the very most, I could probably only have it extended about 1/2".
I'm thinking I'm just going to go with it as it is.
Also, thanks for the information on the driveshaft diameter. Again....I start over-thinking things when I really don't need to.
Pat
To Driveline Length
