C1 Clutch pedal over center adjustment
Hello Guys,
Need a little help here. I`m rebuilding a 62 from the frame up. Almost back together and installed the pedals to hook up the brakes and clutch. When I hooked up the clutch system the pedal sticks to the floor. I have tried adjusted it everyway I can think of including moving the pivot point on the pedal from hole A to C..
This started before I took the car apart. I have replace the clutch and cover, plate and bearing. Install a new fork and install the correct bell housing and pivot ball.
It has a resurfaced flywheel and a diaphragm cover. Replaced the pivot arm and ball on the frame.
I think I have replaced all the parts with correct items. Most were purchased through CC.
I have 2 more 62`s in the garage and they seem to all have some sort of problem.
Thank you in advance,
Harold
Harold
Received 1,126 Likes
Did you try the clutch with the large spring removed and see if it still sticks to the floor?
This will determine if it is the override spring system or the clutch system.
Do you have any pictures of your spring set-up?
Joe
Joe
I will try that tonight and let you know. I can take pictures but this might be a little over my head posting them. I have read the page and got as lost as last years Easter Egg.
Harold
Have you gone through the ST-12 adjustment ???
The "gorilla" spring provides bi-stability - helping both engage and dis-engage the clutch...if its adjusted or installed wrong it'll snap the pedal to the floor in a ghostly manner..
As Joe said, pictures would help as I've seen the gorilla spring incorrectly installed more than once...pics of the attachment at both ends would be helpful..
Thanks Frankie,
I will do my best to post the pictures. I have 2 58`s that work great and they seem to be hooked up the same. How knows. Maybe I need thicker glasses.
Talk soon,
Harold
Talk soon,
Harold
The setup should look like this:
Thanks Frankie,
That looks correct. I read the ST 12 again. I might have the push rod upside down from the pedal to the arm. I see it can go both ways. Right now it is bent up and I think it is in a A hole on the pedal. The picture looks like in should point down if in that position.
I will look tonight after work.
Harold
Harold
The clutch over center is adjusted by the position of 531366. You loosen both of the bolts and it pivots forward/back. Be careful as there is a lot of force from the gorilla spring. I loosen both bolts just a tad and then use a large adjustable wrench on the upper part of the bracket and move it forward or rearward. Its trial and error to get it in the sweet spot.
What type of clutch pressure plate is installed in the car? The original type 3 fingered type? Or, the later and more common diaphragm type? The 3 fingered type is more difficult to depress, so the Godzilla spring is used to help depress it. It goes over center when it's near the top. If you have the usual diaphragm type pressure plate, the effort required to depress the clutch is reduced. Therefore, you don't need the Godzilla spring, although you will need a lighter spring to keep the pedal up. Sometimes using the Godzilla spring on a lighter effort diaphragm type pressure plate will keep the pedal on the floor when it's depressed, especially if it's not adjusted just right.
Thanks to Chris, Frankie and Macaster I have a clutch that works. I look at the other 62`s we have and all have diaphragm pressure plates. None of the 62`s work well. All the 58 have the 3 fingered covers and work great.
I reviewed the info sent by Frankie and all parts are correct on all 6 cars.
I have to agree with Chris, If you do not have the three fingered covers there is no enough pressure to return the pedal and it stick over center. I removed the big spring and installed a return spring like most later model cars and now I have free play and a non sticking pedal. I guess when I have time I will replace the cover with a three finger system for judging. That's going to be a winter project to do 4 clutch systems. I`m glad we have short or no winters in California.
Thanks again for all the words of wisdom.
Harold
Received 1,857 Likes
I have two 61's with diaphragm clutches and both have the gorilla spring and I been driving them for years and the pedal never stuck to the floor.
Did you remove the spring and see if it still sticks?
Joe
Joe
Tether Man
Received 2,018 Likes
2019 C1 of Year Finalist (appearance mods)
