[C1] Stamp Pad Question
Old Oct 1, 2018 | 07:06 AM
Ih2lose's Avatar
Ih2lose
Default Stamp Pad Question
Trying to figure out what motor we have
Casting # from rear of Block is 3737739
From the Book "cars & parts magazine ,catalog of chevy V8 casting number 1955 to 93" ,I found the casting number is
for a 283 for 1958 to 1959 corvette
OR
For a 283 for 1958 to 61 Passenger
Very clearly stamped on the stamp is "F911D" only no other marks
I looked in my books "The Complete Chevrolet V8 engine Pocket Guide" lime and lemon book and could not find a useable reference to the stamp pad unless I am using it wrong
Does any body know a place I can reference what these number mean. We were told it was a GM over the counter warrenty replacement block from the 50's
I guess if I could find a date code on the motor it would help me date the block and as long as it pre dated 1959 we could comfortably assume its a corvette block Can some one point me to where I could see a date code on the block, The car is complete with the motor in the car. I am ordering a new set of Cork gaskets so I can pull the valve covers so we can confirm it has the correct heads on it.
The intake is the correct 3739653 for a 245/270 car , the valve covers have an old 270 sticker on them
Thank you in advance for your help, I am trying to help my unkle sell a Restored 57 and allot of question come up about the motor.
Larry
Old Oct 1, 2018 | 08:15 AM
Panama 58's Avatar
Panama 58
OR
Larry
Larry, your F911D indicates that you have a 283 passenger car or truck equipped with a 2 bbl carb and power glide transmission. Until we know what the casting date is we won't know what year. The F911D does indicate a Flint cast block ( your 739 is correct for this era of block) which is key to Corvette engines, because Flint is where they were all cast, but this is not an original Corvette engine. The 9 indicates September and the 11 indicates the 11th day of September. Interestingly, over the years I have seen many 58 and 59 Corvettes with the D stamp because a G or J can be carefully stamped to the right of the D and all of a sudden you have what at first appearance to be an original Corvette engine. Yours has not received the additional letter, but is staged for someone to do so.
The casting date can be found at the top, rear most of the engine block near the distributor hole. You are looking for a casting similar to the one below and it may
be only a day or two earlier than the September 11 date. You will need to remove the ignition shielding, use a small inspection mirror and read it upside down. I am sure that others will chime in on your post. Good luck.
Old Oct 1, 2018 | 08:23 AM
Ih2lose's Avatar
Ih2lose
Thank you for the thorough reply , The date I thought I could read with an inspection camera was 1082 is that possible? Also where did you find that info.
Thanks Again
Old Oct 1, 2018 | 08:34 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Thanks Again
I've given up trying to post photos here. Something is seriously wrong with the software.
The casting date should be A, B, C, etc for the month of the year, then one or two digits for the day of the month, then a single digit (Flint blocks) for the year.
So. B 14 9 would be Feb. 14, 1959...
Look carefully again.
Old Oct 1, 2018 | 08:54 AM
Ih2lose's Avatar
Ih2lose
Long time no Speak Chuck, Yes I will look again understanding I should be seeing a letter
Old Oct 1, 2018 | 09:09 AM
Chuck Gongloff
FINALLY got a picture to post. This is after about 10 tries. Something isn't right... and it's not me.
Old Oct 1, 2018 | 09:11 AM
Chuck Gongloff
Here's another
Old Oct 1, 2018 | 09:18 AM
Ih2lose's Avatar
Ih2lose
OK could what I think is a "1" actually be an "I"
"I" Letter
"08" Day
2 ? Year I will have to revisit to see what it is
Old Oct 1, 2018 | 10:12 AM
emccomas's Avatar
emccomas
Chevrolet used the LETTER 'I" in casting dates to represent the month of September (9th letter, 9th month). So, If it appears, it will be the first character in the sequence. The casting date code sequence is:
Format = X ii j
X = a LETTER between A and L that represents the month the block was cast
(A = January, B = February, C = March, D = April, E = May, F = June, G = July, H= August, I = September, J = October, K = November, L = December)
ii = a one or two digit number between 1 and 31 that represents the day of the month that the block was cast.
j = a one digit (Flint engine plant) or two digit (Tonawanda engine plant) that represents the year the engine block was cast
The LETTER I was not used in date codes on stamped parts (like alternators, etc.)
(A = January, B = February, C = March, D = April, E = May, F = June, G = July, H= August, J = September, K = October, L = November, M = December)
RULE OF THUMB:
The letter I is OK on dates that are cast (blocks, cylinder heads, etc.) , but not used to represent the month on dates that are stamped (alternators, starters, distributors).
The letter I was used as the digit 1 on stamped parts.
There are exceptions.
Old Oct 1, 2018 | 10:17 AM
emccomas's Avatar
emccomas
This engine code "F911D" decodes as follows:
F = Flint engine plant
9 = September (and must be 1959 or earlier, since Chevy started using a leading zero for the month starting in the middle of 1960)
II = 1th day of the year
D = Engine code (so this must be a 1958 or 1959 engine, since D was first used in 1958 (except there was a ''D" code used in 1956 for big truck) = 283, 170 hp, 2bbl, powerglide, in a passenger car.
Old Oct 1, 2018 | 11:24 AM
Panama 58's Avatar
Panama 58
JV04, thanks for confirming what was provided in my earlier reply. I do think that what you may be seeing is an I because your stamp is September which is the ninth letter of the alphabet, your casting date of the 8th perfectly aligns with what I would expect to see on an engine dated the 9th. Keep working on the identification of the last number.
Old Oct 1, 2018 | 11:27 AM
Panama 58's Avatar
Panama 58
Thanks Again
OP, there are many sources for these numbers. Here's one that I use frequently. http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php
Old Oct 1, 2018 | 03:49 PM
Ih2lose's Avatar
Ih2lose
OK GOT IT , the missing zero for the month thru me way off course, With this information I was able to find it in my lime book no problem . That you every one. You just have to wonder how this information was shared in the past.
I am going to put this note on the leading zero in my lime and lemon book and my casting number book so in 10 years when I may need it again I don't go crazy, any other tips on notes I should add to the book
Old Oct 1, 2018 | 04:05 PM
Panama 58's Avatar
Panama 58
I would like to correct one thing in jv04's usual stellar summary of information. The 9 is September, but the 11 is not the eleventh day of the "year" as stated in his summary, but the 11th day of month. In this case September.
Old Oct 1, 2018 | 06:23 PM
Ih2lose's Avatar
Ih2lose
Thank you again, That part I figured out, But what book would I find the julian calendar, I know I had a book with it in it I just forget what one it was.
Although I own a C7 now , In the past I did own a C1 & C2 and knew a lot of this information. And even though I don't own the cars anymore I kept all of my reference books and judging manuals and articles From John Z and some of his old post for future reference,
To Stamp Pad Question
