[C2] Put on 1959 hubcaps
Put on 1959 hubcaps
Hello members,
I bought new stock rims from Corvette Americas and trying to put the hubcaps on but without any success. I read from the forum tricks putting feet at bottom and hit with rubber mallet between 3 and 9 o'clock but it won't go on. I have spent about one hour trying to put on just one hubcap. I even put some white grease at the 4 nubs of the rims but still won't go on. Any other idea? I have never seen a hubcap that is so difficult to put on. I don't think I need to sand down the nub a little bit?
Aftermarket wheels / hubcaps
Hello members,
kdnguyen (10-05-2018)
Thank you for the idea and I bought a standard bottle jack from the store. However, I believe it only works when it sitting up like on a level surface. I have tried horizontal setup like in the picture and the jack won't come out. I think it only work on level surface standing up. Was your model a special one that you can jack up horizontal?
It's just possible that reproduction wheels are made with slightly thicker steel. (I didn't even know there was a reproduction of the C1 wheels) That would be typical for newer wheels to meet todays safety specs. If that's the case, the wheel would be made to the same outside dimension but be slightly smaller on the inside dimension. That would make installiong the wheel cover very difficult.
As an example, a friend with a 65 mounted his new radials on late Chev S-10 Blazer spare wheels which are close in dimensions. He tried to install the covers but never was able to do so. I tried to help but I wasn't able to install the covers either. I measured the thickness of the old and new wheels and there was definitely a difference. The new wheels were thicker which reduces the inside diameter of the wheel. (I don't remember the exact dimensions) He eventually gave up because he didn't want to damage his 65 wheel covers.
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Hello members,
I installed the repro wheelcovers on a 62 with reconditioned nub wheels about 17 years ago . It was fairly difficult but eventually I got them on. The powder coating on the nubs was scratched off . I used a 4 lb. rubber dead blow hammer. After the initial l installation the covers now go on quite easily.
I have never had to resort to a bottle jack of several tons capacity to install a dang wheel cover....likewise I've never had to park my butt on the ground and use my two feet to install one either.
That includes all major car brands over 50 years, not when they were new, not when they were old and had dinged up wheels and not with my brand new repro 63 wheels.
Someone needs to take some time and figure out what the real issue is.....something is out of spec or someone has soft hands or is not aggressive enough with their technique.
Installation on brand new, reproduction Corvette Specialties reproduction 1963 wheels - I realize the attachment is different than C1s (no nubs) but its still a friction fit with spring fingers on the cover. There are no issues with the dimensions, configuration or finish on the wheel:
Received 1,535 Likes
https://www.youtube.com/watch?v=YLsoJpimKKE
I have to align the cap on the rim. Squat down and put both knees on the cap at about 4 and 7 o'clock. Then take a large rubber hammer (dead blow is easier) and alternate from side to side tapping the cap on. I have had to adjust the tabs on some caps.
hubcaps on repo wheels
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I had the exact same experience with reproduction caps on my original wheels.
I would encourage you to keep trying.. Each attempt stretches the metal a little bit in the right way.
It's very frustrating, I know. I would estimate I spent 2-3 hours to get 4 of them on the first time.
The good news is it only takes me 5-10 minutes now.. After they sit on place for a while.... they take the proper shape.
The key for me was to NOT place any portion of the cap "all the way" on the rim.
You have to just start it in one place, then go around and even it up... then push it on a little further... rinse and repeat.
I have never seen a full cover go on that easily that does not become a frisbee at the first pothole.
Been driving with them for months at speed and down the brick streets of my small town....and they stay tight and flush to the wheel edge...
One thing the jack would be good for is putting enough pressure on the cap to line it up to the center of the wheel and keeping cap there. And then tapping on the edge of the cap with a rubber hammer. I do not think he was implying to put the full force of the jack on cap.
