[C2] Dash Lights
Old Oct 12, 2018 | 04:28 PM
JimSR's Avatar
JimSR
Default Dash Lights
Lost my dash lights on 1963 is there a in line fuse some where or will I have to replace headlight switch? Jim
Old Oct 12, 2018 | 04:31 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
did you try a rotate the headlight switch **** back and forth
Old Oct 12, 2018 | 05:40 PM
raylag64's Avatar
raylag64
The fuse is called "Instrument Panel" I believe.
Old Oct 12, 2018 | 05:52 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
If it’s an original 63-only headlight switch with an “095” then try to avoid replacing it.
Old Oct 12, 2018 | 05:54 PM
emdoller's Avatar
emdoller
My dash lights went out on my 67 a few weeks back. After reading on this sight I found that my brake lights went out as well. It was a simple fuse that fixed it.
Ed
Old Oct 12, 2018 | 08:15 PM
65GGvert's Avatar
65GGvert
Ed
Tail lamps, not brake lights. The dash light fuse gets its power from the tail light fuse via the dimmer switch on the headlight switch
Old Oct 12, 2018 | 10:13 PM
emdoller's Avatar
emdoller
Oops! Yes, tail lights. It’s been more than a week so I forgot already.
Ed
To Dash Lights
