Getting zapped while sandblasting!
Fortunately I didn't have bare arms touching it.OK, the darn light inside the cabinet must have a short, so I unplugged the adapter, and put in one of those HF freebie lights, with a whole bunch of LED's. In the back of my head I'm a little surprised it put out enough juice to zap me but oh well. I resumed work - and I'm STILL getting shocks!
Finally put a couple of 2x4's on the concrete floor and stood on those, and had no further problem. Put the cabinet light back on and still no shocks.There are NO wires going to the blast cabinet. There is the rubber hose for the air inlet, and there is the plastic shop-vac hose to suck out the dust. Obviously neither of those is live. Am I right in thinking the blasting generated static electricity? Ive used the cabinet probably 15 - 20 times since I got it and never had this issue. If it matters, I'm shooting 80-grit glass bead media.
In the floor of the shop a couple feet away, there is a piece of threaded rod embedded in the concrete where a previous owner had a compressor anchored. I'm thinking of taking a wire from some metal screw or other in the cabinet, and running it to that stud for a ground.
Anybody else encounter this? Any other ideas or suggestions? Thanks!
Doug
I had not thought about that aspect.
I love this Forum - learn something new here every day!
Dan.
The light probably is no help as a ground - not sure just what voltage but it has a transformer or whatever like a phone charger, and a very thin wire from that to the light. I'm guessing it's a very low voltage and the cord is not useful as a ground. And also I w as getting a zap both with, and without, the light being plugged in.
I'll try one step at a time. First I'll ground the cabinet and if that fails I'll try a wire from gun to cabinet. Or the other way around. I'm just glad it first happened when i had a couple layers on, instead of summer with care arms!
I first noticed the phenomena when i was demonstrating a new technique for vacuum loading 50 lb bags of calcium carbonate into a 1000 gallon mix tank under the fluid level. (Tank was under a vacuum), using metal perforated wand attached to a 2" diameter flexible plastic hose with the wand stuck inside the bags of CaCO3. You could suck a bag empty in about 3-4 seconds
I felt my hair stand on end big time, and a customer reached out and touched my arm.
I felt a shock, but he called me all sorts of bad names and danced around after a 6"- 8" spark jumped from my arm to his finger. You probably know what a 3/4" spark from an 40KV ignition coil feels like....this was probably a 200KV spark
Wrapping a stainless steel multistrand ground wire from the wand to the metal valve on the tank stopped the problem.
Doug
