[C2] removable cross member flange
Cause I had to take out the transmission for replacing the TO bearing anyway, I decided to convert to a removable cross member.
Many threads on the topic. For those who want to go that road, I include here the DWG format flanges that can be used by a metal shop with a CNC machine or laser/high-pressure-water cutter.
1960 (08-27-2022)
hmmm, the zip file does not get in the attachments, any suggestion?
this is how I fitted them on the car. The inside is slightly cut oversize , cause I put them slightly inclined ('negative caster') to facilitate removal. The small top hole was threaded, but there was no simple way to put the bolt in place with the small clearance so I skipped that
Still could not find out how to post the DWG file.
1960 (08-27-2022)
That's nice work Alexander. I've had to pull my transmission enough that it's tempting to do that on my car. Guess I'm not a purist but must be a first cousin or I would do so.
1960 (08-27-2022)
The following 2 users liked this post by skids:
Rob_64-365 (12-01-2018),
TRP_IV (10-30-2021)
Received 1,962 Likes
If you really want to pay the price.
https://americanpowertrain.com/i-238...corvettes.html
Xmember file
Guru of the wrench (08-12-2020)
sure, on what email can I send it?
Thanks for sending me the CAD file! How wide was the section that you cut from your cross member, and was it equal on both sides as measured from trans mount center line? -Aaron
no dimensions, been a while...Here some picture that give you a flavor of how it's done. There are many other threads on this subject that show where to cut. I recommend to cut slightly tapered (meaning that the bottom cut is wider than the top, to ensure an easy drop-out). So the flanges are welded slightly inclined (not too much otherwise the holes no longer align, say 1/2 inch difference is enough. )
sure! what is your email, i'll send it to you
Hello Alexander,
Could you please send me the file as well. I would like to do this mod as well.
My email is: juhvelo@yahoo.com
Thanks for your help!
Br,
Juha
Br,
Juha
done! Anyone knows if/how this could be made a sticky? I get requests regularly.
Alexander
Alexander
