Opinions on swapping out original 327 350 with crate big block on a 67 coupe.
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Well, I was gonna stay out of this.................................and I probably should.........................but here goes anyway. I have a matching number 67 coupe, 327-350 engine, 4 speed. I purchased the car in 2006 and enjoyed it for a couple years as a nice small block driver. I had always wanted a big block Corvette so in 2008 I decided to go all out and build an L-88 tribute car. I found a new ZL-1 aluminum block and all new GM components (heads, crank, rods, pistons) for about the same money, and probably a little less than what I would spend on the iron block and 67 aluminum heads.
Everything was a direct bolt in and I have the power of a big block with the weight of a small block. I kept every piece, every nut and bolt I removed in the conversion and it could easily be converted back to a 100% matching number car in a few days. Ten years later and I have no regrets in making the change and I don't feel it devalued my car in any way. I know some may disagree and I appreciate and respect your philosophy on this topic. I'm not getting any younger and I have enjoyed the car since I made the conversion. I'm not a "show circuit" kinda guy but I appreciate those who are. To each his own.
I guess my point is / was.................................it's your car. Enjoy it the best way you can.
Thanks,
Rex
Thanks,
Rex
The following 6 users liked this post by Dr L-88:
427Hotrod (11-25-2018),
59BlueSilver (03-07-2019),
happymike63 (03-07-2019),
Lotsacubes (11-25-2018),
Mike C#2 (03-07-2019),
and 1 others liked this post.
Received 6,944 Likes
2015 C2 of Year Finalist
Rex your build is top notch with the sum of added parts costing more then what most on here paid for there car. Not to take away from anyone else just by throwing in any old BB motor won’t help the value. Unless you do like you did.
Received 1,121 Likes
2017 C2 of Year Finalist
Considering the tires that’ll fit in your stock wheel wells, anything with more than 400 HP at the rear wheels is overkill. That level of power is easy to get out of a stroker small block, without resorting to anything exotic or the new hood and stuff that a big block will need.
Go with a crate 383 from Blueprint (or similar). The swap is easy, with a good warrenty, and the rest of your 327 parts fit too. You’ll probably need to upgrade a few powertrain components (halfshafts, for instance). Put the original 327-350 (maybe the best motor Chevy ever built) on a stand and go for it.
Received 1,843 Likes
No need for a poll. Post #30 says it all. You either have the Real McCoy or you have basic transportation.
PS. If you have no experience with owning/driving both types engine in a Corvette, you're not qualified to vote or express an opinion.
Received 3,043 Likes
St. Jude Donor '05
Thanks,
Rex
Thanks,
Rex
Not like anyone cares about mileage anyways if they are they are in the wrong hobby. I bet it doesnt affect value at all, either people love it or hate it there is not one kind of buyer.
everyone in favor of the small block makes very valid points, yes you can reach both the HP levels and Torque of a BB, But its not a BB, 40 years ago I owned a very nice numbers matching 67 427/400, I could never get enough of the way it sounded and the feeling of being pushed back into my seat, I sold that car when I got married ( regretted it every day going forward) it wasent until 1995 that I could afford to look for another, sadly Big Block 67's were way above my price range, what I did find was a 65 L76 that was mostly original but tired. after doing a ton of work to it I have a nicely sorted L76 that could put a hurting on just about any stock BB, But..........its not a BB, and to this day I still lust after having one, so having said all that my plan is shortly after I retire next year I will be installing a BB into my 65, and if all I ever get to do is raise the hood to look at it, I will be a very happy camper, so to me its not about de valuing the car, its not about making sense, I really could care less, its all about what I want, If the car is ever sold, all its original parts will be stored. but it wont be me selling it, it will be one of my kids. Do what pleases you, not what pleases everyone else.
Many comment how much nicer they drive with the SB. Many love the torque and fury of the BB. I spent ~$1200 on a set of Brodix Race Rite aluminum heads that match my stock L72 intake and exhausts. L72's about 665 lbs dry. L76's about 550 lbs dry (per Google). Now my L72 is within 10-15lbs of the SB with all the joys a BB brings (don't have or want PS/PB BTW). I won't call $1200 pocket change, but I considered that an inexpensive enhancement. The aluminum heads allowed a 10.5:1 CR to make my fuel selection simpler. And... it looks like an L88, revs to 6500+, weighs close to a SB. I did lots of other engine enhancements, some for hp, some for bottom end durability. Anyway... wanted a BB since 1973 after riding in a friends 427. Had to do it before the dirt nap. It's a hobby. Follow your heart. If a 10k hit either way affects your retirement you need different hobby. Cheers
St. Jude Donor '05
agree with lotsacubes....a sbc will never match a BB power across the board. Peak they can sometimes come withint shouting distance but you wouldnt want to drive it.
My 383 makes damn good peak but bottom end tq? Compared to a BB forget it no contest. Do the big block...still want one sometimes
Some compression, a good set of heads, a healthy solid flat tappet is all you need to scare the chit out of you. Dont go nuts on teh seat timing it will last a long time.
Plenty of guys going 10s and 11s with a simple combo like that & drive them everywhere
Stan's Customs (03-10-2019)
