[C2] Alternator Recommendation? 100amp, BB car
Hey all;
So I picked up all new repro PS/Alt brackets as I am trying to put Power steering onto the Red Car (65 with a 71 454 LS-5 motor) and I bought the kit from Long Island Corvettes. All the brackets are on and I now realize my existing Alt does not have the correct mounting set up.
So, A, what is the right class of Alternator and 2, any recommendations? I have electric fans and a stereo so I want to keep with 100am.
Also, as you can see in the pic, my crank pulley needs to be replaced with a 2 groove one. I'd like to not get the heavy cast iron one... Any recommendations?
Received 6,943 Likes
2015 C2 of Year Finalist
take it to your local auto electrical repair shop and have it upgraded
No Man, the Alternator I have works fine, but the mounting holes in it don't line up with the new brackets....... I need a new Alt with mounting holes in the right place....
Sorry if I was not clear....
RON
It’s a short pump. No Corvettes ever used a long pump as it won’t fit
https://www.ebay.com/itm/1969-70-ss3...6Rp4:rk:5:pf:0
RON
If you're adding PS, the alternator can't be any bigger case size than an original Delco externally regulated one. The alternator brackets don't pivot to accommodate a big case alternator like in your pic, and the factory size case barely clears the driver side valve cover. There are aftermarket hi amp units that have smaller cases than original. You can also retrofit a correct case Delco unit with 100 amp diodes and stator coil. You'll also need the correct alternator pulley for PS, like this one for 390/400 HP cars, there's a slightly larger diameter one for 425/435 HP cars.
https://www.corvettemods.com/C2-Corv...iABEgJvQ_D_BwE
1Cerberus4u (12-10-2018)
