[C2] How the **** do you reach the fuse block?
Old 12-13-2018, 11:41 AM
pgiganti
pgiganti's Avatar
Where are these primary buss fuses and where can I buy circuit breaker fuses to replace them?
Hardscrable
Hardscrable's Avatar
Originally Posted by pgiganti
Where can I find one of those plastic fuse removers/putter inners?
Auto parts store...probably even wally World
Old 12-13-2018, 11:54 AM
RatDog
Support Corvetteforum!
RatDog's Avatar
Received 1,581 Likes on 818 Posts
St. Jude Donor '20-'21-'22-'23-'24
Sometimes they come inside the pack of fuses. Sounds like you may be needing more fuses before you've sorted this problem anyway.
Steve
Old 12-13-2018, 03:24 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
There's another fuse for instrument lights, (marked "panel" or "inst) it would kill all your dash back lights. It is usually 4a Another possibility if all your dash lights are out, the tail lamp fuse will also kill all your dash backlights. (marked "tail) They are the next two fuses above the one you changed. Both those fuses must be good to get dash lights. I find it easier to reach by kneeling as we said and go in head first facing down and rotate your upper body slightly clockwise. I don't do well working upside down.
pgiganti (12-13-2018)
Old 12-13-2018, 03:38 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
This really sounds like an old geezer problem to me.
I don't recall any problem changing fuses in C1/C2/C3 cars when i was 18-20 years old.
You can buy a fuse puller at any FLAPS store. Make sure you get one for round fuses and not blade fuses.
Doug
65GGvert
65GGvert's Avatar
PS. If you use a meter or test lamp on the fuse clips to see if you have voltage on both sides with the park or headlights on, you can save pulling and reinserting a fuse that is good. The reason I said on the clips is the fuse may be good, but corroded around the end and not making contact with the clip that holds it. All four of the fuse clips on the two fuses I mentioned above should have 12v with the lights on.
Old 12-13-2018, 03:53 PM
ptjsk
ptjsk's Avatar
Received 1,901 Likes on 883 Posts
Isn't it always a good time trying to get to anything under both a C1 and a C2?
It does help to take the seats out and lay upside down in the floor area. LOL!
Pat
Kerrmudgeon (12-13-2018)
Old 12-13-2018, 03:58 PM
RatDog
RatDog's Avatar
Pat
That's cheating.
Steve
Old 12-13-2018, 05:15 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Pat
Pat's got it right for anyone bigger than a girl. Two bolts if I remember right.....and out it comes. Any work under the dash for that matter. I actually fell asleep under there redoing the dash on my 66!!
ptjsk (12-13-2018)
Old 12-13-2018, 05:33 PM
smacota1
smacota1's Avatar
God to be young again and own a C1 or C2. What immensely more joy we would be having working on them. ( and know what we know now!!!!!)
Old 12-13-2018, 05:34 PM
smacota1
smacota1's Avatar
Now that is too funny.
Kerrmudgeon (12-14-2018)
Old 12-13-2018, 05:42 PM
RatDog
RatDog's Avatar
If you remove the seat and the steering wheel, not only can you achieve easy access to the fuse block and everything else under the dash, you have room to throw a party for half a dozen of your closest friends. You really do get a lot of working space.
As as far as falling asleep under there, that’s always a possibility for me. So is being being able to get out of there. My wife has a strict rule. If I’m going to be working under the dash or under the car, I must have my cell phone with me.
Steve
Old 12-13-2018, 05:47 PM
  #33
AZDoug
AZDoug's Avatar
Taking out the seat and wheel sounds like a lot of work to change a fuse, but sometime you gotta do what you gotta do. My '72 is a seat removal type car for about everything under the dash, but i am going to blame it on the design rather than my age.
Its better than getting trapped inside the car, upside down.
Doug
Old 12-13-2018, 05:52 PM
  #34
Hardscrable
Doug
My C3s have been easiest by removing seat. Lying on back or standing on head are almost a necessity as my old spine/neck doesn’t rotate or twist any more
Old 12-13-2018, 06:12 PM
  #35
RatDog
RatDog's Avatar
All of us old geezers on here are really pathetic (and I’m including myself in that). But you have to give us credit for hanging in there and fighting the ravages of old age. One way or the other, we figure out how to get ‘er done.
Steve
The following 2 users liked this post by RatDog:
Panhead (12-13-2018), ptjsk (12-13-2018)
Old 12-13-2018, 06:23 PM
  #36
Hermn59
Hermn59's Avatar
Steve
Bullsh!t. I am 56 and I am in awe of what you all get done. I work ~60+ hours a week behind a computer, and then ache and moan getting up and down off the garage floor on the weekend. I only hope to get as much done as you self-proclaimed geezers.
Old 12-13-2018, 06:56 PM
  #37
Sibes67
Sibes67's Avatar
and just wait if someday you also need glasses, WITH bi-focals in them; talk about a tough time even seeing the fuse you want to pull.
Oaker57 (12-16-2018)
To How the **** do you reach the fuse block?
Old 12-13-2018, 07:34 PM
  #38
pgiganti
pgiganti's Avatar
I've also discovered that the more stuff I remove in order to fix something, the more likely I'll damage something else in the process AND discover something else that needs fixing. And the bigger the thing you remove, such as a seat or an engine, the VERY MUCH more likely I'll damage something else and 100% sure to find many things that need fixing.
LateOutDrsMn (12-14-2018)
Old 12-13-2018, 07:47 PM
  #39
RatDog
RatDog's Avatar
It’s called project creep.
Steve
Old 12-13-2018, 09:16 PM
  #40
Hardscrable
Steve
I have buddy that started turning wrenches as a kid. Work in “ filling station”, then a Ford dealership, then a 30 year Naval jet mechanic, etc. We sometime “tag team” jobs. Recently changed a starter on one of my Vette. One would be on the creeper, the other would get wrenches, etc. Then guy on creeper would get a cramp and we would change places. Etc., etc... Took us a while but we finally got ‘er done. Then kick back, have an adult beverage, rest, shoot the bull.
Quick Reply: [C2] How the **** do you reach the fuse block?
