Coil wire
Old Dec 15, 2018 | 09:17 AM
409/409's Avatar
409/409
Default Coil wire
About 3 years ago I bought a set of braided spark plug wires for my '66 427. Somehow the coil wire burnt through and needs to be replaced. I can't find anyone who sells just a coil wire, much less the proper length. I would even be happy with buying a good used one. Does anyone know where I can purchase just a coil wire about 4" to 6" with 90 degree boots on both ends???
Thanks in advance.
Old Dec 15, 2018 | 09:24 AM
Avispa's Avatar
Avispa
Time for a trip to the junkyard. I've never been able to find individual wires for a motor with a distributor at any store. A coil wire from any 1974 and earlier GM v8 car will fit inside the distributor shielding. Save the boots from your original wire. Wire with straight distributor terminals can be coaxed into angle terminal wire using a 90 degree boot. Did that to make a set of braided shield wires out of a Bosch aftermarket set of plug wires.
Old Dec 15, 2018 | 12:46 PM
MelWff's Avatar
MelWff
unless you need it to be OE, auto parts stores sell wire by the foot. You should be able to reuse the boots and metal ends.
https://www.autozone.com/ignition/pe...eset-bulk-wire
Old Dec 15, 2018 | 12:58 PM
409/409's Avatar
409/409
The boot for the coil end has a hole burnt through it. I'd gladly buy a good used one. I never had good luck making my own ends.
Old Dec 15, 2018 | 01:07 PM
BLUE1972's Avatar
BLUE1972
Go to your local speed shop, they have them in 7mm to 12 mm thick wires with and without the ends attached.
To Coil wire
