Would you rather - original and matching number or modified C1
As I unfortunately haven’t yet had the privilege to drive a c1 and I’m imbarking in purchasing one soon - wanted to get peoples options.
I want ant to be able to take the car out and obviously enjoy it and currently have found two. One is all original matching number 1959 single barrel with power glide. All mechanicals have been overhauled and rebuilt.
The other is a 1960 which has been upgraded with a 327ci with electronic points, 2 speed power glide and disc brakes etc.
what way would people go???
Popular Reply
12-22-2018, 07:32 AM
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
I agree with Frankie on both his points.
Catalog-engineered cars with "upgrades" scare me. There is a risk that the "engineering" behind the "upgrades" neglected one or more important parameters and will fail. Too, the quality of the install depends on the skill of the person doing the work, always a big unknown.
I trust the original engineering which went into these cars. I'm not saying it reflects modern thinking because it obviously doesn't. But it does reflect the careful consideration of the engineers of the day and they were really sharp individuals.
Jim
Jim
??? I'm not hearing much difference between the two except the larger motor will hae a little more umph....
Electronic points are a wash. If it was a coin toss I'd rather have the original car all day long - no brainer for me...
Jim
Jim
The following 9 users liked this post by jim lockwood:
ah53 (12-22-2018),
blue_74 (12-23-2018),
C.T. (12-22-2018),
jimgessner (12-22-2018),
leif.anderson93 (12-22-2018),
and 4 others liked this post.
Received 6,944 Likes
2015 C2 of Year Finalist
Jim
Jim
2023 C1 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared))
2019 C1 of Year Finalist (track prepared)
As Frankie, Jim, and Nowhere are saying, not much difference in the "enjoyability" of the two examples you cite. I'd pick the '59 because it's more original. Are you sure you want an automatic?
Some of the guys on here really don't like the way solid axle Corvettes drive. I always wonder how many cars they've been exposed to. If a solid axle Corvette has been maintained properly, it will drive much the same as a no power steering-brakes Sting Ray, as long as they're both running fresh radial tires. If the steering and front suspension are worn out or improperly adjusted they're a real handful, like every other old car. You don't know which you're going to get until you go and look at it and drive it. Even the restored cars are seemingly often put together by guys that never heard of a torque wrench, because they drive like crap if not properly assembled.
Real tall husky guys don't fit well in them. I'm 6'2" 195 and I fit fine in my '57.
The following 2 users liked this post by Todd H.:
ptjsk (12-22-2018)
Received 4,713 Likes
If I am buying a C1, I would want the original car if possible
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
You guys are making a big deal over a few mods between the two cars the OP listed. Simple upgrade to a 327, disc brakes and a distributor upgrade are not a big deal. Personally I would rather have the bigger engine and disc brakes. OP only asked for a pick of the two cars listed.
Roger Walling (12-23-2018)
This is key before you even drive one. When I was selling my 57, there was more than one potential buyer I had come by that I knew wouldn’t buy the car the second I saw him get out of his car. At 6’ 1” and 175 lb, I was okay, but bigger guys around the waist were not. 58-62 do have more room than 56-57.
Received 5,554 Likes
Depends on how you want to use it. If your primary plan is to be judged, only drive it to shows, and crave originality (stamping, markings, and everything as it was from the factory), then stay stock with the ‘59. If you plan on driving it regularly and it is more about the drive, handling and comfort, go with the ‘60.
Personally, my ‘61 was my daily driver, so an upgraded engine, overdrive tranny, power steering, power disc brakes, small steering wheel and more comfortable/roomy seats was mandatory. Same with my ‘64 today. If outward appearance is you primary concern and you want to drive it regularly, there are upgrades you can make that don’t change the outward appearance much if at all, yet improve the driving and safety experience substantially. Good luck!
Lol, you are a broken record at a time when records are obsolete.
Received 3,043 Likes
St. Jude Donor '05
Youll have to drive both, you may fall in love with one...or neither.
As said "restored" means nothing if the work was done by a hack. THese are old cars and need to be looked after periodically
Buy what you really like..if youre doing it for $ or what others think youre not going to enjoy it at all. Stock, what color, options or not doesnt matter.
6'3 220 Ill probably never be able to fit in one.
2021 C1 of the Year Finalist - Modified
I myself would take the upgraded one . My 60 has lots of power and needs lots of stopping ability, but let's not start that pissing war about drum vs disc brakes AGAIN. "To each his own" I like Hot Rods !
records are making a come back weather you believe it or not. But why do you find that funny. How did all those new car owners drive those cars new when they didn’t know any better. I will admit I am spoiled by new cars but when it comes to driving old cars I enjoy the simplicity that comes with it.
You and I represent two ends of this hobby. What was good enough in the 60’s is not good enough for me today. We are both aligned that these are great vehicles, but I believe if I can add modern performance, comfort and safety while preserving the beauty of the original design I should do it. The GM designers in the ‘60 were limited by the technology of the time. I am not. We both show our position across multiple threads where you question anyone who wants to change or upgrade from original and I encourage people to pursue their own originality. Your response is predictably, “If you want modern performance and comfort, buy a modern car.” This position completely misses the point. The design, the simplicity, and the rawness of the experience can be preserved while making the car yours and unique in its own way to please your personal vision. It is not about either/or, it is about both.
The following 3 users liked this post by Factoid:
No but to tell people these cars are no fun in stock form is where I have a problem. I agree you can make these cars into anything your bank account can pay for. But not everyone wants a reto mod and not everyone wants a stock car. I get that. But let people figure that on there own by getting a base line of what stock is. My biggest regret on my Chevelle is I never drove one without power steering, power brakes and disk brakes. But I added all that to mine. If I driven it without all that I might not ever needed to up grade. I driven Corvettes with both and I could care less either way. And your responses are predecitble too. So let’s agree to disagree. But there is plenty of room in this hobby for both guys like us. We just need to respect OUR opinions
The C1 in original trim is truly like driving a "fast tractor"
That was the allure of it in my '61.... I'm C1-sized at well under 6' and 175lbs with my shoes on....it does make a difference...
I won't get into the urinary competition about engines, but as I stated, gimme the original motor over the "mystery mill" that may or may not be a dog or have cobbled together parts....
There is the consideration of future value and I would think, all else being equal, the original car is the better expenditure of funds... But opinions are like......mmm....what's that saying again ?
Here's my 2 cent.
I would not buy a vette with a power glide transmission again unless I was unable to drive a manual. For me, driving a sports or muscle car with a manual is a much better driving experience and may be harder to sell in the future.
if the car is not completely original you won't feel guilty about making performance and safety upgrades.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
I liked my 1958 to be as stock as possible, but as Frankie says, they are like driving a tractor. Radial tires are a must.
