[C2] '65 AC Pictures Needed Please
Would a forum member have the following AC Pictures of the engine bay for a ''65?
Hose routing from Condenser to compressor
House routing from Condenser to Evaporator
POA Valve position, and brackets
I have the assembly manual but i need the detailed pictures.
Heater hose routing around the front of the AC compressor
Hot Water Shut Off Valve position and brackets
Respond here or email me at Philr153@gmail.com
Thank you and Happy New Year
Phil
Phil
Phil
Phil
No pics.......sorry about that. I am sure others will have. But I can offer:
1. Factory stock had a STV valve and not a POA.
2. Heater hoses at/near front of compressor used a special bracket to hold them in position and to prevent kinking as the came off the engine and turned to the rear.
3. Heater shutoff valve is on the inlet to the heater core and uses a special holding bracket attached to the firewall. Hose between valve and heater connection was very short and determined by the bracket position. Water valve vacuum connection for factory valve pointed straight down. If you follow these instructions there is no room for misinterpretation or incorrect installation of this valve.
Larry
856666 (12-27-2018)
I'll get some pictures for you, but should mention that in 1965 it was not a POA (pilot operated absolute) valve, but rather an STV (suction throttling valve). Differences are minor, but if you're going for originality it's significant.
When rebuilding my system I found the AIM to be invaluable. Everything you need to know is in there; locating and deciphering the information will take some time, but it's definitely worthwhile.
856666 (12-28-2018)
856666 (12-28-2018)
856666 (12-28-2018)
Thanks to everyone who sent pics and advice.
What I discovered is that my '65 has a '67 condenser and the hose/tube routing is fragmented from the condenser to the '65 pieces.
I couldn't figure out what was going on because some of my parts match the assembly manual and some don't.
Anyway I finally figured it out and have the correct items on order.
Thank you,
Phil
Thank you,
Phil
Just another Corvette guy
Nice pics SW.
That was just a pic i grabbed off the web somewhere. These guys will do it:
https://originalair.com/gm-stv-rebui...l-spring-style
But I did my own
edit: the 65 shop manual supplement has the step-by-step procedure for a rebuild; probably a 2 out of 5 star DIY level of difficulty if your valve isn't badly corroded.
But I did my own
856666 (12-30-2018)
Thank you,
Phil
Thank you,
Phil
856666 (12-30-2018)
STV and Condenser Fitting
Thanks again for the detailed pics
I am now working on the condenser/dryer fitting issue - see pic with 67 condenser
Question - The Condenser fitting is resting on the rad support - is the condenser mounted too high? Is it the wrong rad support?
See the hole below the fitting, there is another below it - this is for the fitting from the dryer to the Evap. I can move it down one hole and it will still work to the dryer.
I ordered the condenser fitting for the 66L-67 and hope that it will fit in the top hole.
STV issue resolved -see before pic
Phil
Phil
856666 (12-30-2018)
856666 (12-30-2018)
Is this the "before" pic?? Because the STV needs to be rotated 90 degrees CCW from the looks of things, and the mounting of the hot water valve doesn't seem right either. Better get that sorted before even starting to put the A/C components together.
Yes the pic with the fitting next to the manifold is the before - it looks more like your pic now see attached pic below.
I am still dry fitting the hoses
I still need to get a STV bracket to secure it - (let me know if you have one) and resolve the condenser fitting issue.
Thanks again for the pics
Phil
Phil
856666 (12-30-2018)
