[C2] 66 Differential Code AN
Old Dec 29, 2018 | 10:14 AM
SoCalErv's Avatar
SoCalErv
Army
Default 66 Differential Code AM
Here are the codes for 1966.
Can someone explain to me the difference in the "AM" "Manual Transmission" description as the other ratios have 4-Speed notations.
CodeRatioTypeAK3.36:1Standard Manual Transmission or Powerglide (327)
AL 3.08:1Positraction 4-Speed (327)
AM 3.36:1Positraction Manual Transmission (327)
AN 3.55:1Positraction 4-Speed (327)
AO 3.70:1Positraction 4-Speed (327)
AP 4.11:1Positraction 4-Speed (327)
AQ 4.56:1Positraction 4-Speed (327)
AR 3.08:1Standard Wide-Ratio 4-Speed (327)
AS 3.70:1Standard Close-Ratio 4-Speed (327)
AT 3.08:1Positraction 4-Speed (396/427)
AU 3.36:1Positraction 4-Speed (396/427)
AZ 3.55:1Positraction 4-Speed (396/427)
FA 3.70:1Positraction 4-Speed (396/427)
FB 4.11:1Positraction 4-Speed (396/427)
FC 4.56:1Positraction 4-Speed (396/427)
Note: All 1965-67 Corvette rear axles were manufactured at Warren and are suffixed “W”. Listed 1967 “AQ” and “AR” codes & ratios may only have been used early in the 1967 model-year, or not at all.
Old Dec 29, 2018 | 10:26 AM
smacota1's Avatar
smacota1
I am no expert but could mean the 3 speed transmission. Brighter minds I am sure will correct me if I am wrong.
Old Dec 29, 2018 | 11:57 AM
Powershift's Avatar
Powershift
You are (almost) correct. It the specific case of "AM" it is a posi-traction rear axle approved/available for both the 3 speed and 4 speed transmissions for the small block engine
Larry
EDIT: If only 4-speed is shown, 3 speed and auto trans cars could not obtain it as a factory approved option. But $$$$ also talks, and perhaps a special order could be done. Maybe.
To 66 Differential Code AN
