[C2] Source for engine harness?
Old Jan 17, 2019 | 09:04 AM
Factoid's Avatar
Factoid
Default Source for engine harness?
I’m getting ready to pull the engine and tranny from my ‘64 coupe. The new engine moves the alternator to the driver side to make way for an A/C compressor. The alternator was already “upgraded” to an internal regulator model and there will be some other upgrades. Plus, some of the wiring is very suspect with unknown wires bypassing the firewall connector via the tach drive cable grommet, some crispy wires and aftermarket cheap connectors.
Does anyone have a source for an engine harness that plugs right in to the firewall connector that reconfigures the alternator to the left side and eliminates the external regulator?
Old Jan 17, 2019 | 09:09 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Lectric Limited has them
Old Jan 17, 2019 | 09:28 AM
Tampa Jerry's Avatar
Tampa Jerry
M & H also makes great harnesses. Can't go wrong with either company. Look for the best price. I also upgraded my three cars to internal voltage regulators, One less thing to worry about. Jerry
Old Jan 17, 2019 | 09:32 AM
Tom Austin's Avatar
Tom Austin
Also research American Autowire - there was a thread on here recently @ this company!
Old Jan 17, 2019 | 10:29 AM
Nowhere Man
Not to derail this thread. But how?? No matter if it’s external or internal you still have one and they need to work
Old Jan 17, 2019 | 10:37 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
fewer connections to deteriorate in the wiring harness
Old Jan 17, 2019 | 10:41 AM
Nowhere Man
don’t tell that to my 50 odd year old harnes then
Old Jan 17, 2019 | 11:00 AM
BADBIRDCAGE
wouldn’t think of it. And why are you running around on a 50 year old harness that was designed for a less than 20 year life expectancy? Isn’t your pristine classic Corvette worth a couple hundred dollars in safety upgrades? Heck, I carry a fire extinguisher in my C6. You just never know.
Old Jan 17, 2019 | 11:09 AM
Nowhere Man
only in my Chevelle and dads unrestored 67. One of these days I will replace the engine harnes in my Chevelle. But right now I have no electrical gremlins.
Old Jan 17, 2019 | 11:38 AM
Factoid's Avatar
Factoid
Keith, Jerry, Tom thank you!
Lectric Limited seems to be the go to in this case as they have the exact harness with external regulator delete, aftermarket A/C and alternator on the driver side for the best price.
Old Jan 17, 2019 | 11:42 AM
Nowhere Man
Paragon Corvette sells LL products and sometimes beats there price.
Old Jan 17, 2019 | 02:44 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Mark, You are getting good suggestions. Also....I sent you a PM. Dennis
To Source for engine harness?
