Car continues to crank...
...after I release the key. This was a on my "65 GTO. The car didn't start and just as the battery was dying I pulled the negative battery terminal-probably wrong thing to do. Any help will be appreciated.
TIA
Joe
TIA
Joe
Joe
ah53 (01-20-2019)
Received 5,554 Likes
Assuming nothing changed since you last started it (no component replacement, etc.), start with the ignition switch. They can stick in the start position. The easiest way to check this is to remove the wire from the S terminal on the starter, then with the negative battery terminal disconnected, check continuity from the wire you removed to the positive battery terminal. If you have continuity, troubleshoot from there (pull the connector from the ignition switch and see if the circuit opens, etc.)
Next questions: Have you changed anything electrical recently? Were there any other symptoms (e.g., gauges remained on when the key was in the off position)? Did the engine fire and run? Is that what you would expect of the engine?
First off, install a battery cutoff switch on the negative post.
I've heard of this before and seen it once....IIRC the worn flywheel teeth can get hooked enough to hold the starter drive engaged. Otherwise the starter solenoid is not releasing as the key moves to ON from START....an electrical issue.
Received 1,843 Likes
Most likely a stuck solenoid.
I'd start with a test light on the starter terminal to check for power after you reconnect the battery. If you have power, the problem is in the "start" circuit. If you have no power, either the solenoid is stuck or your battery is completely dead.
Notice how the solenoid extending moves the contact plate at the rear to connect the battery directly to the starter motor. If the solenoid can't retract, either because of sticking, a broken spring, or binding in the flywheel teeth, the 12v stays connected.
Dan Hampton (01-20-2019)
Thank you all for your suggestions. Time for me to get to work. First thing is to get a cutoff on the negative terminal and then check continuity as per Factoids suggestion. I will report back when done.
Joe
Joe
If you're not swept up in the matching numbers to the third decimal place stuff; a GM solenoid can be obtained from Pep Boys or elsewhere and bolted on in about 30-45 minutes...
Use a knife-blade cutoff switch not those rinky-dink **** jobs...
ah53 (01-20-2019)
Location: Various places in California. Not currently aflame.
Have you owned the car for a while and this is a new problem? If so, I'd think it's likely the ignition switch or the solenoid.
If those are the source of the problem, it may be the flywheel/flexplate teeth holding the starter gear in the extended position. I had this problem with my '64. I added a shim to the starter and the problem was fixed. You can measure the clearance on the starter gear to the flywheel teeth with a standard paperclip.
