Vent Window Upper Rubber Stop Screw Repair?
Received 1,966 Likes
Look what I found on the garage floor next to the '66 this afternoon!
So . . . I tried to re-install it in the passenger side vent frame, and it would seem that the screw won't seat properly - looks like the vent threads are stripped! Now what? . . . anybody have a repair that would work? . . . one size larger screw possibly? Thanks!
Tom
Tom
Received 6,995 Likes
2015 C2 of Year Finalist
carefully fill the hole with JB weld. wait until it cures. then drill and tap?
Tom Austin (01-21-2019)
Looks to me like the threads on that screw are flattened out. Did you try a new screw first?
Received 3,443 Likes
Oversize screw will work. Also you can place a bit of wire or wood into the hole and screw the screw in. Or even aluminum foil to 'thicken' the screw. Then there is the helicoil route. Doubt the JB method would be strong enough, but it might be, and is an easy one to try. Do NOT over-tighten.
The following 2 users liked this post by GTOguy:
Bluestripe67 (01-21-2019),
Received 2,136 Likes
I have this exact same issue, so I'll try the above tips. Dennis
Now that the winter vortex has left town, I had an opportunity to get back in the garage and attempt this repair. I figured I'd try the "wire method" first, so I stripped the insulation from a 12 gauge piece of copper wire, threw away 1/2 of the copper threads, and twisted the remaining threads loosely and folded them into a tight "V". I inserted the V into the window frame and inserted my old screw and began to tighten . . . the screw quickly grabbed and held firmly as I tightened the screw all the way in. This repair is DONE! Total time? . . . less than 5 minutes! Thanks to all for the tips!
Tom
Bluestripe67 (02-03-2019)
That is a very common problem the threads are deep enough to use a longer screw I run a tap in to clean the threads and use a 1/2 inch long screw. Some times you have to shorten the screw a little but this has always worked for me.
Mark
Mark
