big block intakes
Old Jan 24, 2019 | 04:58 PM
sgtniko's Avatar
sgtniko
Navigator
Default big block intakes
Hi all , George here , trying to find out what after market intake manifold will fit under the stinger hood of my 66 big block , any help would be great. Thanks
Old Jan 25, 2019 | 01:57 AM
blown454's Avatar
blown454
Mine is a '67 but I was able to get a Dart intake and a Victor Jr. under the factory '67 big block hood. The carb did have the choke horn milled off and I used the factory drop base for the air cleaner. I also used a slightly shorter air cleaner element but I can't remember the height. Hope that helps.
Old Jan 25, 2019 | 06:30 AM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
I don’t know about aftermarket, but I’m using a GM 3963569 with a 4150 Holley and have plenty of clearance under my 67 Stinger hood, even with a 1” spacer.
Old Jan 25, 2019 | 08:15 AM
Avispa's Avatar
Avispa
This one should fit rectangle port heads:
https://www.holley.com/products/inta...lds/parts/8018
For oval port heads:
https://www.holley.com/products/inta...lds/parts/8019
Edelbrock RPM Air Gap manifolds apparently don't fit under a stock hood. Their website doesn't even show older kinds of manifolds these days (old Performer RPM, Torker, etc.). An old Torker 2-O manifold for oval port heads will fit, tight but all under a stock 65/66 BB hood. Had one on my '65 NOM 427.
Old Jan 25, 2019 | 08:33 AM
VetteZr's Avatar
VetteZr
Here is a link to ebay for a new factory reproduction Winters intake priced at $359, https://www.ebay.com/itm/1965-Chevro...3/350906393119
Old Jan 25, 2019 | 08:37 AM
aswile's Avatar
aswile
Wieand Stealth on my '66 BB with factory air cleaner and hood.
To big block intakes
