[C2] Aftermarket EFI sytems
#41
The following 3 users liked this post by Black_Magic:
#43
Platinum Supporting Vendor
It is not really about if the car is worth more or not. It would be worth more to a collector if it was all original. As a driver, it is as a fuel injected car because you can actually drive it when you want so to speak. It doesn't matter if is 15 degrees outside or 100 degress, it is going to start and run good. You are also not going to stink like burnt fuel all the time and depending on the system you get it can control timing and it will have a better handle on it then the mechanical and vacuum advance.
So the FiTech is good, we have sold a bunch and installed them and no issues yet. I have had one fuel regulator that we do not even use on it go bad, but that is a bosch product and not a FiTech issue. The Fast was a great system 10 years ago and for a stand along system it is still good. Holley bought everyone that was anyone in the business minus Fast. I am getting ready to install a Sniper system but that system is on the same level as the FiTech. If you want to really move up you need to go to the Holley Dominator or HP ECU's. There is a ton of technology built into them and they are easy to program and get running.
Stan's Customs (03-02-2019)
#45
Received 5,615 Likes
To the OP, when (not if) you do this, please start a detailed build thread as it will be very interesting, plus may help dispel some of the no longer valid concerns that regularly crop up about the voodoo of efi.
Loren Smith (04-24-2021)
#47
I have an Edelbrock Pro-Flo 4 on my C1. So far, so good. Supposed to be self-learning, though I haven't used the (provided) tablet to check if it's changed anything.
Kris_K (04-16-2021)
#48
I have a Mass Flo sequential EFI installed for 5 years now. Has been perfect. System includes distributor and ignition with a single plane intake. Has a port if you have a problem you can plug in and
check engine code. Never have had to use it. Self learning and ECU controls everything.
I love the Holley sniper, but if you have the extra money, the port injection efi from mass flo is worth it. You can literally bolt it on and drive cross country.
RJ1 (01-29-2019)
#50
I don’t like the expense, but I would argue that this is the best system on the market! Chris is an amazing engineer and the self tuning on this system is just phenomenal! I’ve used two of his systems and they run flawlessly.
#51
Well, based on this thread and my desire to have fuel injection, but concerned about the additional work, I just bIt the bullet and ordered my engine for fat boy. Did you know if you order a Blueprint engine with a Holley Sniper, they will set it up and dyno it with your system installed? That was enough for me!
The following 2 users liked this post by Factoid:
633BR (04-11-2021),
Rob_64-365 (01-30-2019)
#53
#54
Has anyone had experience with the Edelbrock Pro Flo 4 system? I'm considering one on my '58. The engine I have is a NOM 283 low HP with Rochester F.I. I'm having perc problems that keeps me sort of "grounded". I was thinking of using their sump pump system instead refitting the fuel tank. Any thoughts? I am looking for better reliabillity and not speed and such.
#56
Received 6,548 Likes
C2 of Year Finalist (track prepared) 2019
They are described in detail in this thread. Have you seen it?
How to fix FI fuel perc
#59
Thanks Jim, yes I followed the thread closely and I have been gathering some of the stuff to try to solve the problem, ie nylon bolts for the injector block hold-downs, the fan to cool the spider and associated ducting and the electric fuel pump. I have yet to install these but expect to get to them soon. I thought of contacting you on the mods you did with the steel fuel lines and the conversion to reroute fuel back to the F.I. pump. I'm not the tinkerer that a lot of members like yourself are but appreciate y'alls thinking here. To me, the mods reflect a lot more than just tinkering.
Thanks to all,
Gary
Thanks to all,
Gary
#60
Thanks to all,
Gary
Thanks to all,
Gary
If you decide to convert to the steel fuel lines and add fuel recirculation, I'd be happy to help.
