[C1] 58
Old Jan 28, 2019 | 05:50 PM
Saul Marinkovich's Avatar
Saul Marinkovich
2nd Gear
Default 58
My dad has a 59, it has lost all steering and we have to pull it out of the garage backwards, is there any towing points on the rear?
Old Jan 28, 2019 | 06:05 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
air up the tires
get it jacked up slightly so that you can straighten up the wheels without using the steering wheel if needed.
Old Jan 28, 2019 | 06:39 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
You can flat tow backwards to pull it out by wrapping a recovery strap around the rear axle.
Old Jan 28, 2019 | 06:53 PM
Saul Marinkovich
2nd Gear
Originally Posted by jimh_1962
air up the tires
Yes but is there any towing points on the rear to pull it from?
Old Jan 28, 2019 | 07:22 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
NO.
As Jim mentioned, wrap a towing strap around the rear axle and pull it by the strap.
Old Jan 28, 2019 | 07:44 PM
Vette5311's Avatar
Vette5311
1st off what do you mean "lost all steering". If it's broken linkage you could have front wheels go different directions and cause damage to body from hitting something. If this is the case go to Harbor Freight or such and get roller plates to put under the tires. If it's a s/w disconnect then you can turn wheels by hand as you go. JMHO
To 58
