[C2] Adding Booster '67---Line Length
Putting a booster on my manual brake '67------if I can get the 52 year old plug out of the intake.
My question is will the stock brake lines give enough to put the master cylinder in it's new position?
Thanks!
Thanks!
Not sure if this will help but this is what I did. My 66 had manual brakes that I wanted to convert to booster. I installed the booster and the new dual chamber master which came with the distribution block (with the brake warning sensor). The kit included the two short lines that connect the master to the block which lived beneath it. It also came with a new cross-member distribution block. The OE block accepted the single line from the OE single chamber master and diverted the fluid in three directions (two front and one for the rear). The new block eliminated the aft take off. I built a new line to connect the front MC chamber to the new cross-member block for the front brakes. I found that the OE rear brake line was now long enough to carefully reshape it vertically and that it was just long enough to mate up with the rear MC takeoff. Careful shaping and it will not interfere with the clutch linkage. So far it works just fine.
If you splice, use Parker or Swadgelok industrial rated fitting(s), or flare the tubing and use a flare coupling.
Larry
