1966 Clock Repair help
I took my clock apart so I could get the gears in it working. I was able to do that, but when I applied voltage to it it still would not run.
I suspect when the gears got hard to turn the coil burned up in it. Can I just buy just the coil for the clock somewhere? I know I can send it off to someone, but I am one to test my skills on things that don't work.
Thanks for your help.
Don
Don
clock
There is a set of points in the clock if it is of original design, these points snap open when energized winding the clock . You may find that the points are stuck , if so you may be able to open the points manually , winding the clock, with luck and a little exercise it may work. If not you can buy the internal mechanism and replace it yourself , both the original design and an quarts are available, check with the various corvette vendors , I doubt you'll find just a coil . Hope this helps Jeff
Clock Works put an OEM style Borg mechanical movement in my 63 clock for $159.
In 1990s Instrument Services Inc in Janesville, Wisconsin sold parts for 1963-67 Corvette clocks.. I have a parts list that lists Magnet Coil Assy for $4.00.
Phone # 800 558 2674
(608) 755 0993
(608) 755 0993
If the gears turn when moving the escapement by hand, they may need cleaning or lubrication. I used a few drops of acetone at gear bearing points and that loosened them up. Be sparing with the acetone as it is a strong solvent. You might not need any oil - I didn't and it's running years later.
Any ideas on how to fix this issue?
Thanks,
Dex.
Received 1,857 Likes
When I open the points up, my clock works perfectly. But as soon as I apply power, the clock stops. I've sprayed the gears with WD-40, exercised the gears by turning the winding **** (or whatever it's called, and get the same result.
Thanks,
Dex.
Thanks,
Dex.
Thanks JohnZ! Today, I tested the points and there was no continuity from one side to the other, thus not allowing the ground to reach the relay. I put on my magnifying glasses and saw a black spot in the center of the receiving side of the points, so I used my pocket knife to remove it. After that I had continuity, but it was late so I didn't test it again. Hopefully either tomorrow or Thursday I can connect the 12VDC power supply to it to see if it works before I put it back together AGAIN.
Thanks,
Dex.
Thanks,
Dex.
I found this video that shows how to replace one of the contact points. Not sure if this is what I'd do or not, but it worked.
Thanks,
Dex.
Thanks,
Dex.
UPDATE!!! Tested the clock and all is working fine. I filed both sides and no continuity and just one spec kept it from touching. It's amazing what a little spec of whatever can cause issues!!!
Thanks,
Dex.
Thanks,
Dex.
We all talk about filing the points in the original mechanically wound clocks, and it does work many times, I know because it was something I did to mine in 1969 and it worked 'like a clock'.
However, for longevity purposes, use a fine grade of emery paper as a final step on the contact points. The smoother the final finish, the longer the clock will continue to work before requiring its next 'filing'...
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Thanks,
Dex.
The solenoid or "coil" in my 1967 clock has fried as shown by the black film on the middle of the windings. Does anyone know how to go about rewinding the solenoid? What are the steps to remove the electromagnet from it's mount?
Pro Mechanic
Received 1,303 Likes
2023 C1 of the Year Finalist - Modified
Don
Don
